Originally Posted by
Lindasan
do you have a monitor? connect that to the D-sub and restart
I just connected the HTPC with a D-SUB and a DVI monitor, all works fine, clone mode and other stuff was able to select.
But as soon as I feed the second monitor with HDMI instead of DVI to following happens:
Vista sees the monitor and shows me its name, I can edit things like resolution and stuff in the nvidia settings control center. It even shows me the HDMI cable connection where I can switch between the 420p, 720p, 1080i and 1080p resolutions.
But the screen stays black...
I really don't know what to do and I'm only about a inch away from kicking the whole HTPC out of the window. The computer sees the monitor but sends no signal, why?
And how to fix that?
Or did I really get a second MB that is broken in a way?
