I have been making measurements of digital signals with my Sadelco 719E signal level meter (SLM) for about a year. Even though it is calibrated for peak reading of analog signals, I have found that it is very useful for making
comparative measurements of antennas and digital signals.
I would like to have a new SLM that is designed for digital signals, but it is not now in the budget. But what about the people that don't have either? I keep thinking of a poster who lived close to the transmitter towers and had an attic antenna. He was having trouble receiving signals. Was it that the signals were so strong they were causing overload because they only had to go thru wooden siding or were they too weak because they were blocked by aluminum siding or an aluminum foil vapor barrier?
I made some signal measurements with my Apex DT502 to see how it would do as a SLM. After the antenna, I used a switched attenuator with 3dB steps (as in the Kelvin link in my signature) going to a splitter and then to the DT502 and the SLM; first in a strong signal location:
Code:
Attenuator Quality Strength dBmV dBm
dB % %
0 100 84 +12.5 -36.3
3 100 84 +9 -39.8
6 100 83 +6.1 -42.7
9 100 83 +2.9 -45.9
12 100 83 +1.4 -47.4
15 100 81 -2 -50.8
18 100 78 -4.9 -53.7
21 100 74 -8.5 -57.3
24 100 69 -12 -60.8
27 100 65 -15 -63.8
30 100 61 -18.5 -67.3
33 100 59 -20.5 -69.3
36 100 54 -24 -72.8
39 100 51 -27 -75.8
42 100 46 -30 -78.8
I next added a preamp to simulate a very strong signal bringing it up to +36 dBmV, but the DT502 signal strength never went any higher than 84%. I was also looking for signs of overload, but didn't see any. I would have to drive about 100 miles round trip to pick up an extremely strong signal, but it doesn't seem worth the trouble right now. The ultimate test of a tuner would be to see how it would handle a very weak signal when other very strong signals are on the band. That's for another day.
and then in a weak signal location:
Code:
dB % %
0 100 59 -18.3 -67.1
3 100 55 -21.8 -70.6
6 100 50 -25.0 -73.8
9 100 44 -29.0 -77.8
12 100 42
15 67 33
18 30 18
21 0 0 Dropout
I was able to test a 2nd DT502, and the results were similar: It maxed out at 87% strength at +2.2 dBmV with an increasing signal, and held 100% quality down to 51% strength just below -30 dBmV with a decreasing signal.
It looks like the DT502 can be used as a SLM. Its tuner is even more sensitive than my SLM.
CAUTION: As Trip correctly pointed out to me, this CECB doesn't allow you to add other channels after the scan. See wiki other features note code "-N" of CECB comparisons:
http://en.wikipedia.org/wiki/Comparison_of_CECB_units
Update: I have received some positive feedback from IDRick:
Originally Posted by
IDRick
Interesting data Rabbit! I have a DIY 4-bay antenna in my attic. Adding a reflector increased the signal strength reading on my two lowest strength channels 5 to 6% (readings before and after with APEX 502). Based on your second table, I increased the gain by 3 db. The modeler who designed the DIYer has routinely observed an 3db increase with field testing (reflector vs no reflector). Results appear to match well!
IDRick
Rabbit, there was additional confirmation that I failed to nention in my earlier post. I have three strong UHF stations that registered between 81 and 84 in the attic. None of these stations increased in signal strength after adding a reflector. Great job!
IDRick
While I certainly agree that there are far better tools for measurement, the CECB's can be very useful for finetuning antenna location. In my case, I have broadcast towers in two directions (200 and 270 degrees). My DIY 4-bay does a nice job of receiving signal from both directions with proper placement in the attic. The APEX 502 was invaluable for optimizing signal strength of my two lowest channels (1 at 270 and 1 at 200 degrees) and deciding final antenna location/orientation.
Signal quality readings from the APEX also had practical application. My antenna is connected to two tvs and a computer capture card. Anything less than 100 on signal quality scale results in audio and video dropouts with the capture card. I get marvelous recordings with proper placement of the antenna (optimized signal strength and signal quality = 100). I'm sure top quality equipment could fine tune my setup even further. I'm satisfied with a $20 tool versus a several hundred dollar tool, especially for a one time use.
Downunder in .au land, they have a good understanding of the importance signal quality, BER, and MER:
http://www.dtvforum.info/index.php?showtopic=18627 see post #11
http://www.dtvforum.info/index.php?s...=360&start=360 #366 & 369
http://www.hillsantenna.com.au/arbitrage/pages/61 BER
http://www.hillsantenna.com.au/arbitrage/pages/60 MER
http://users.tpg.com.au/bitek500/Dow...M%20instal.pdf p4 DVB-T digital cliff
http://www.bbc.co.uk/rd/pubs/papers/.../crn-dvbtm.pdf ATSC vs DVB-T, excellent charts on p3
http://www.wowvision.tv/signal_strength_meters_BER.htm Signal strength meters and BER
