AVS › AVS Forum › Audio › Speakers › Bose Lifestyle Speaker replacement
post #1 of 8
My wife's stepmom's parents have an old Bose Lifestyle system with white speakers. I just hooked up a new Samsung LCD ln52a630 for them and the white speakers really standout now. The easiest thing to do would be to replace the white speakers with black but it doesn't look like you can just buy the speakers. Can you hook up any other brand speakers to this system?
post #2 of 8
An equivalent set would be some tin cans and a string.
post #3 of 8
Thanks for the insightful reply.
post #4 of 8
Realistically, the smartest option would be to sell the Lifestyle set (since it has good resale) and buy something that offers much better sound quality and will also blend in with the decor to their satisfaction. There are many options that have great WAF at less money.
post #5 of 8
Well, you would have gotten much more of a response if you had:
1. Specified your price
2. Specified your size wanted
3. Source material
4. 5.1?
5. Speaker locations
etc.
You give no information, you get no information. You pretty much just said that your wife didn't like white speakers and that was it.
post #6 of 8
3. Source material
4. 5.1?
etc.
Your reading comprehension is lacking. It's my wife's stepmom's parents that have the old lifestyle system. My question was if the current speakers could be replaced with another brand.
post #7 of 8
The Lifestyle system is made to specifically work with the cube speakers. AFAIK, it is not possible due to the proprietary connections.
You wouldn't want to upgrade to good speakers only to connect it to the Lifestyle anyways.
post #8 of 8
Thank you that's what I needed to know.
  Back to Forum: Speakers
