I have had my 4805 over 4 years.
On the third bulb.
Its been back for a light tube failure about 18 months ago after getting the yellow stripe on the left before finally collapsing giving half a picture!
Its just developed the yellow stripe again so it probably wont be long before
it will collapse again.
I think its gone as far it can, although noisy its been great and I have more than had my moneys worth out of it.
I dont have a huge budget <$1000 for replacement
The placement is tricky because of the low ceiling
Its ceiling mounted 12' 6" from a 100" diag screen (87" x 48" 16:9)
Its hung so its throw misses a flush mount celing fan approx 9 ft from the wall.
I did look at the MIT HC1600. The throw is right at that range although the offset looks a little steeper. (can probably keystone it????)
I looked at the Sharp Dt 510 but the throw looks really short for my set up.
Can anyone suggest a good budget projector that would be at least as good as the 4805 and fit my current set up.
Thanks in advance for any help.
On the third bulb.
