Hi guys. Just looking for some built in refridgeration recommendations for my basement project.
I plan to put in a fridge and a kegerator that will have the tap mounted on the granite bar top. I would also like to be able to use the kegerator as a fridge most of the time.
I would also like any other appliance recommendations that you think a basement bar should consider.
