Originally Posted by
aramis109
I'll tell you why I think it's not.
...it's the same sub as
this only with a different woofer. I'm not sure if you're aware, but Bic America got a cease and desist on using the copper-colored speakers that looked VERY close to a certain Klipsch setup. It could be in connection to this. It could be that they've decided to change their speakers based upon cost, performance or any other factor.
Not many of us (not me, anyway) are concerned that it's not on their web site. Also, Bic isn't Premier Acoustics, though it's certainly easy to confuse the two based upon the ebay postings or the confusion on the forums.
If all you have to contribute is negativity and no information... maybe it's time to move on? If you're looking for information, check back once people start receiving their subs.
Are you a moderator? If not, you can take your directive for me to move on and shove it. If you are, let me see if the confusion can be clarified. First of all, does it not concern anyone that there *IS* confusion where these subs are concerned.
If Bic is not the same as Premier Acoustics, why do their subs look nearly identical?
The ebay guys call the PA-120 a Bic sub but clearly the "PA" designation would say it is a Premier Acoustics. So which is it? Or are the REALLY one and the same?
If this is a Premier Acoustics sub, does it matter if Bic got a cease and desist order on using copper colored drivers? It would only matter if the companies are one and the same. Or, perhaps, their common Chinese contract manufacturer is really the one that got the cease and desist order. And, by the way, I have some bad experiences with LCD TV companies where the supposed American company was really just a front for a Chinese company that was supposedly only the contract manufacturer.
Again, this sub doesn't show up on either of their websites but I have compiled the specs of relevant subs below. What is interesting is that the PA-120 shares the amp with the Premier Acoustics PA-12W but shares the enclosure design with the Bic H-100 and Bic VK-12. All of the PA models (which I assume are all supposedly from Premier Acoustics) have polygraphite drivers like the H-100 has but clearly the PA-120 differs in form from the rest.
It could be that this is a great sub but I would be a lot happier if there wasn't this identity confusion and the sub showed up on one of their websites and preferrably the Premier Acoustics website since that seems to be the most logical source.
Bic Acoustec H100
Price (MSRP): $499 / Each
Design: Heavy Duty Front-Firing 12" Powered Subwoofer, BASH designed amp.*
Frequency Response: 24Hz - 200Hz (+/- 3dB) variable (adjustable crossover)
Sensitivity: 90 dB
Drivers: Heavy Duty 12" Long-Throw Poly-graphite woofer with high power magnet.
Magnetic Shielding: NO
Gold-Plated Terminals:YES
Recommended Power: Built-in Amplifier Power - 150 Watt RMS, 500-Watt Dynamic Peak
Impedance: 8 ohms
Dimensions: 17" H x 15" W x 18 1/4" D
Weight: 42 lbs Each
Warranty: 2 Year Parts and Labor.
Bic VK-12
Price (MSRP): $599/Each
Design: 12" 1000-watt peak, Heavy Duty Front Firing Kevlar*Subwoofer with BASH Amp.*Contemporary laquer top & bottom.
Frequency Response: 24HZ -200HZ (+/-3dB), Bypassable 24dB/oct. continuously variable 30-90 Hz low pass filter
Sensitivity: 92dB
Drivers: 12" Premium Grade Kevlar woofer.
Recommended Power: Built in BASH Amplifier: Power 250-watt RMS, 1000 watt peak
Impedance: 8 ohms
Dimensions: 17"H x 15" W x 18 1/4"D
Weight: 48 Pounds
Warranty: 7 Years Woofer, 2 Year Amplifier
Bic F-12
Price (MSRP): $449/Each
Design: Front-firing 12" 475-watt peak powered subwoofer
Frequency Response: 25Hz - 200Hz
Sensitivity: 90dB
Drivers: 12" Injection molded woofer with heavy duty surround
Magnetic Shielding: YES
Recommended Power: Built-in Amplifier Power: 475 watts Dynamic Peak, 150 watts RMS continuous
Impedance: 8 ohms
Dimensions: 17"H x 14 3/4"W x 17 1/4"D
Weight: 42 Pounds Each
Warranty: 5 Years Parts & Labor
Premier Acoutics PA-10W
MSRP: $499
Design/Driver: Front-firing polygraphite 10" Active Subwoofer
Sensitivity: 85DB
Ohms: :8 Ohms*
Frequency Responses: 24HZ-20KHZ span (?!)
Wattage: 150- 500 Watts
Size: 18.35" x 13" x 15.75" (H X W X D )
Weight: 46 pounds each
Warranty: 5 year Warranty
Color: Cherry or Black
MSRP: $599
Design/Driver: Front-firing polygraphite 12" Active Subwoofer
Sensitivity: 85DB
Ohms: :8 Ohms*
Wattage: 200- 650 Watts
Size: 19" x 14" x 19" (H X W X D )
Weight: 56 pounds each
Premier Acoustics (??) PA-120
MSRP: $599/Each
Design/Driver: Front-firing 12˝*Premium Grade Polygraphite Titanium Color Subwoofer Cone
Wattage: 200 watts RMS, 650-watts peak
Weight: 60 pounds
Warranty: 5 Year Warranty Woofer, 2 Year Warranty Amp
Inputs: Speaker level and RCA inputs
Size: 17˝ H x 15˝ W x 18-1/4˝ D
Colors: Black or cherry with Black Lacquer Top and Bottom
Is this enough information for you...jerk?!?!
