SO that means that the specs from sounddistributors.com is probably accurate and not what is being posted by the ebay seller. Now this makes the box different from the H-100 and puts it closer to the PA-12W, which isn't a surprise. It is a little shallower at 17" vs. 19". I would think a smaller volume probably means the driver had a higher natural resonance frequency. Can a DIYer confirm? I'm assuming all other factors being equal. It is also interesting to note that the weight and amplifier specs are similar to the PA-12W. So is the SPL sensitivity. That's a potential concern because 85dB is pretty low and 5dB lower than the H-100. Even though he H-100 can only run 150W continuous versus 200W for the PA-120, 5dB is a factor or 3 higher for SPL!!! Of course, that is at 1W of power and I don't know what the SPL is at 150W. I'm sure it isn't linear over that power range.
Here is the updated Specification list with the new information:
Bic Acoustec H100
Price (MSRP): $499 / Each
Design: Heavy Duty Front-Firing 12" Powered Subwoofer, BASH designed amp.*
Frequency Response: 24Hz - 200Hz (+/- 3dB) variable (adjustable crossover)
Sensitivity: 90 dB
Drivers: Heavy Duty 12" Long-Throw Poly-graphite woofer with high power magnet.
Magnetic Shielding: NO
Gold-Plated Terminals:YES
Recommended Power: Built-in Amplifier Power - 150 Watt RMS, 500-Watt Dynamic Peak
Impedance: 8 ohms
Dimensions: 17" H x 15" W x 18 1/4" D
Weight: 42 lbs Each
Warranty: 2 Year Parts and Labor.
Bic VK-12
Price (MSRP): $599/Each
Design: 12" 1000-watt peak, Heavy Duty Front Firing Kevlar*Subwoofer with BASH Amp.*Contemporary laquer top & bottom.
Frequency Response: 24HZ -200HZ (+/-3dB), Bypassable 24dB/oct. continuously variable 30-90 Hz low pass filter
Sensitivity: 92dB
Drivers: 12" Premium Grade Kevlar woofer.
Recommended Power: Built in BASH Amplifier: Power 250-watt RMS, 1000 watt peak
Impedance: 8 ohms
Dimensions: 17"H x 15" W x 18 1/4"D
Weight: 48 Pounds
Warranty: 7 Years Woofer, 2 Year Amplifier
Bic F-12
Price (MSRP): $449/Each
Design: Front-firing 12" 475-watt peak powered subwoofer
Frequency Response: 25Hz - 200Hz
Sensitivity: 90dB
Drivers: 12" Injection molded woofer with heavy duty surround
Magnetic Shielding: YES
Recommended Power: Built-in Amplifier Power: 475 watts Dynamic Peak, 150 watts RMS continuous
Impedance: 8 ohms
Dimensions: 17"H x 14 3/4"W x 17 1/4"D
Weight: 42 Pounds Each
Warranty: 5 Years Parts & Labor
Premier Acoutics PA-10W
MSRP: $499
Design/Driver: Front-firing polygraphite 10" Active Subwoofer
Sensitivity: 85DB
Ohms: :8 Ohms*
Frequency Responses: 24HZ-20KHZ span (?!)
Wattage: 150- 500 Watts
Size: 18.35" x 13" x 15.75" (H X W X D )
Weight: 46 pounds each
Warranty: 5 year Warranty
Color: Cherry or Black
Premier Acoustics PA-12W
MSRP: $599
Design/Driver: Front-firing polygraphite 12" Active Subwoofer
Sensitivity: 85DB
Ohms: :8 Ohms*
Wattage: 200- 650 Watts
Size: 19" x 14" x 19" (H X W X D )
Weight: 56 pounds each
Premier Acoustics (?) PA-120
Design/Driver: Front-firing polygraphite (?) 12" Active Subwoofer
Sensitivity: 85DB 1 Watt 1 Meter
Ohms: :8 Ohms
Frequency Responses: 24HZ-20KHZ (?!) ( +/- 3DB)
Product Size: 18.7" x 14.3" x 17.1" (H X W X D )
Shipping Size: 21.7" x 22.7: x 17.7" (H X W X D )
Bic Acoustec H100
Sensitivity: 90 dB
Impedance: 8 ohms
Weight: 42 lbs Each
Bic VK-12
Sensitivity: 92dB
Impedance: 8 ohms
Weight: 48 Pounds
Bic F-12
Sensitivity: 90dB
Impedance: 8 ohms
MSRP: $499
Sensitivity: 85DB
Ohms: :8 Ohms*
MSRP: $599
Sensitivity: 85DB
Ohms: :8 Ohms*
Ohms: :8 Ohms
...all I can say is that I am betting that 95% of the folks out there looking for a sub for home theater would be thrilled with the PA-120.
