All a630 owners please read...
This is a copy-paste from my cnet samsung forum post that I made (I registered there just to post this) because apparantly some Samsung employees view and moderate that forum. I'm really hoping for a firmware update to resolve this issue, and if any other a630 owners could post here regarding their finds with this, all the better...
...I have linked my thread on the cnet forum at the bottom of this post, if you would like to add your comments and finds there, as well. It may help get the ball rolling.
I hope the sammy guys that moderate this forum read this and get a firmware update rolling...I registered here just to post this because I saw that Samsung employees view and moderate this board.
I use my Samsung LN46A630 as a secondary computer monitor to my Acer 24" widescreen LCD. To my dismay, I have found a bug that I believe to be the same one associated with the 650 series (which has been fixed via firmware update). Upon turning the TV on, while viewing the desktop and moving the mouse around, I noticed that the mouse icon shows white pixels around it, as it does when AMP is set to ON. I have AMP set to OFF on all inputs. I tested this further by scrolling some text, moving around windows, etc. and it appears that AMP is stuck ON even when set to OFF, as moving text and objects are glitchy. The only workaround I have found to fix this issue is turning AMP on then off again, which clears up this motion issue. Of course, doing this for every input that I want to use every time I turn the set off then on again, is a big pain in the arse...but required to have a glitch-free viewing experience whilst using it as a monitor (I'm sure it's stuck on while playing xbox, ps3, etc. as well, but obviously I cannot test it like I can with the PC hooked up).
I believe this issue to be firmware-related just like the a650 issue was, and should be fixable. I have a sammy tech coming out to look at it after the thanksgiving holidays (dec. 02), but I am afraid he will not be able to cure the issue save completely disabling AMP through the service menu, if this is even possible.
I have been completely happy with this set except for the AMP stuck bug. Can the 630 owners get a firmware update to resolve this bug as well, please? It makes using the set as a monitor unacceptable until you enable/disable AMP after booting the TV. Once enabled and disabled again, the issue is gone and the motion is glitch-free...until you turn the set off and turn it back on again!
Please, PLEASE, Samsung...give us a630 owners a firmware update to un-stick AMP when its set to OFF!
CNET Samsung forum thread link: ht tp://forums.cnet.com/5208-13973_102-0.html?forumID=146&threadID=317893&messageID=2915739
(copy/paste this without the space in the http part, I had to do this as this was my first post and the system would not allow me to post links yet).
Why do you do this Samsung, WHY?
But I'm rambing...
On the flip side, if the video player outputs the video without the driver tweaks, then your TV settings should remain sufficient but your desktop will be calibrated to your liking. It appears to be win-win either way, but hey - I've been wrong before.
So I will continuously check this thread and report my personal findings as well.
