So, what you're saying is that Netflix HD streaming is just as good as the worst Blu-rays? Okay, but there's some pretty crappy transfers on Blu-ray out there
umenon, framerate shouldn't be an issue, since Netflix is 24 fps, just like Blu-ray.
Netflix HD isn't even worth comparing to the best streaming video I've seen, being Zune Video on the Xbox (I've heard that Vudu is amazing as well, though I haven't seen it). I'm fairly certain that I personally wouldn't be able to tell the difference between the best Blu-ray and a Zune Video 1080p24 stream. Some of the things I've watched there give that same "woah!" experience you get watching the best Blu-ray and it has digital surround sound. (If you have an Xbox, check out the trailer for Planet 51). Of course, the bandwidth requirements to get that 1080p24 stream are significantly higher and it's much more costly than Netflix WI (for those of us who were Netflix subs before the streaming came along, it's essentially free).
.umenon, framerate shouldn't be an issue, since Netflix is 24 fps, just like Blu-ray.
