I have been noticing that once every 30 minutes or so you get what looks like a brief (1 frame) glitch in the picture as you see something happening - though not exactly sure what it was.
Over the past several days I began to realize I was only seeing it only on 720p only channels - none of the 1080i channels.
So I began looking at ABC/FOX East/West on different DVRs (HR20-100 and HR20-700), different TVs and different locations to and it clearly is happening on both. When it happened, I stopped the DVR and stepped frame by frame to see exactly what was happening - and it seems the top part of the frame is correct, but the bottom part of the frame shifts slightly.
I have changed the output of the various DVRs to 1080i and 480i/p only as well to see if it is something in the DVRs (Again, different models - different firmware). All output resolutions show the same issue.
I then went to ESPN-HD MPEG4 feed on 206 to see if the same thing happened there, while also monitoring the MPEG2 feed on Channel 72 on a different DVR.
After 50 minutes of monitoring, yes, ESPN-HD MPEG4 /206 did have the shift. The MPEG2 channel DID NOT have the shift, thus it clearly is an issue in D*s MPEG4 encoders - not their receiving equipment at D's uplink site.
I have searched this and the other site - dbstalk.com - for anything relating to 720p and image shift or breakup etc. I find many reports of breakups on ESPN etc, but usually they are dismissed with many saying "no problem here - reboot your receiver" and no one has yet to connect the dots.
Is this covered anywhere that I am not looking?
And has anyone else taken steps to narrow down this issue making D* aware of the issue?
MPEG4 - Channel 206
MPEG2 - Channel 72
Again, let me stress you will NOT see this with the naked eye - only a quick flash in the picture 1 frame out of 60 in a second - almost like what one would see with a power surge or power spike.
Also, the top to bottom percentage is not ALWAYS the same. Usually its closer to 50/50 than what I am showing above.
MPEG4 - Channel 206
MPEG2 - Channel 72
