Well after tickering with this more the bios are rather lacking in areas. In the manual its says you can wakeup from USB or something like that. (I dont have manual near me at the moment.) But if u go to that setting its not even listed in the bios. Not a big issue for me though as mine still wakes up from sleep in S1 & S3 mode.
Others have had issues trying to install raid on there boards because they say the setting isnt there to do it. Refer to EVGA forums about the guy whinning about that. I havent had that issue yet. I just installed raid 1 this weekend without any issues. So Im not sure what hes talking about not be available.
He then goes on and says: Do you know what happens when you select the RAID option in the bios after you have already installed windows???? Its wipes the drive and you get to rebuild your system from the OS up.
I figured that was a given but apparently he didnt know that. Heres the link to the guy complaining about it.
http://www.evga.com/forums/tm.asp?m=713925
Another thing I noticed was the motherboard SATA connectors supplied with motherboard. There nice with the clip and all but it seems like a very tight fit into the SATA port on the motherboard. Seems like Im going to break it when pushing it in. Other aftermarket connectors plug right in with a little push.
Biggest thing I hate so far is there is no bios update. Granted I dont need one but it seems like others would like one. Other then that I havent had any issues no bsod's or anything. I go to VMC and watch whatever movie I want and all is good and I can record tv at no issues what so ever.
Overall its a solid build for me but with the lack of support for this current board I might try another one. Everything is working for me so i could careless without a bios update.
