AVS › AVS Forum › Audio › Speakers › Yes, another advice needed thread, help me out
post #1 of 7
Ok, so i live in a small town and dont have much other than a CC and BB here to look. Just have not been happy with much that i have heard there and i realize environment takes away.
Current setup : Samsung 50 plasma, Onkyo 5.1 HT-R410 receiver, PS3 as blu ray player connected via optical input.
Anyway, i have read many threads here and have narrowed down the brands i think i might be interested in. AV123, emotiva, infinity, and a couple of others. What i am looking for is a crisp sounding system. Room is approx, 12x18 with tv being on the 12 side. Mostly movies, then games and music. I like to watch movies at theater volumes....loud.
So my requirements are as follows. Bookshelf sized, your average sized ones. Looking for a crisp clean sound....current HTIB speakers sound like they have a piece of paper or something in front of them....muffled sound.
Budget is around 750.00 for 5.0 setup. Have a velodyne sub that will work for now. Also, a good receiver to power your recommendation if you think my current one is out of date. I like HK, Onkyo, Denon, and maybe even a Pioneer.....this would be in addition to the speakers with a separate budget up to 700 ish.
Thanks a bunch for reading it all.
post #2 of 7
Refurbished (with full warrenty) Infinity Beta 20s, 10s and C250 or C360 center.
Check Harmon Audio on EBay.
post #3 of 7
Ok, thought about a few more i have read about here. KEF, Swan, and a couple of others...dont be afraid to let me know.
On the infinity stuff....have seen the primus mentioned a bunch. Are the beta versions better?
post #4 of 7
I have not heard the Infinity Primus line.
I just like my Infinity Beta 40s, 20s and C360 center.
(Outlaw sub woofer)
post #5 of 7
yupp, i have heard good news about these guys
post #6 of 7
For HT I would definately look into SVS, HSU, Klipsch, or the cheaper version of Klipsch....BIC Acoustech.
post #7 of 7
I was able to listen to a couple of the smaller Klipsch speakers locally and dont think i cared for them. Something with the tweeter sound....kinda brassy or something. Was able to listen to a pair of Paradigm atoms today and i liked them, but think i can get a better deal via an ID company as the local store that had them were pretty high.
So, anyone with more suggestions, especially if you have owned your recommendation.
Thanks again.
  Back to Forum: Speakers
