Hello, I just bought a subwoofer, see there http://precision-acoustics.com/hds10.html for my Harman Kardon 3490. I wonder if I connected it perfectly though. I could only connect an RCA plug from 3490 to sub. On the HK there are link switches and trigger outputs. I can't find anything to connect to these outputs from the sub (see photo). So if I understand well, some subs have trigger inputs and some don't. Mine obviously don't. As for the link switch, well...I read the instruction manual and I still can't get it. OK time to laugh! BTW, this Precision Acoustics sub is from the same company that carries Harman Kardon (Jam Industries). They also carry EuroDesign and Sinclair Audio brand. Products all are rebranded. Go to http://precision-acoustics.com/index.html have a look at the picture in the center, you can see clearly a Harman Kardon AVR and newer models of Precision Acoustics speakers. Anyway, is my connection OK? Also, are there some difference in the rendering of the bass when a sub is connected to a 2 ch audio, not an AVR amp like the HK x54 series? Thanks a lot for your hints. Karmin.
