Originally Posted by
vmishra
Thanks Tulli.
There was only one monitor and it was GenericPnP. I updated it. I did not try with Integra processor turned off (didn't think I needed to). So I will try that tonight. Will also try instructions in your sig.
Well, after trying a couple more things it seems like it is working.
- Applied the override with Integra OFF as well.
- Did not find any hidden monitor other than GenericPnP which seemed to be hanging around in addition to the new Overrides. Removed it but it came back after reboot.
- Noticed the second monitor (dual mon video card) was enabled in the screen resolution screen. Removed (disabled) it. But it keeps coming back after reboot.
- Installed latest driver for ATI vid card.
- Installed latest Ceton driver.
After doing all of above and various reboots and system rollbacks (dont ask me) I have somehow arrived in a state that the EDID Override is working.
YEAH !!!!!
The screen takes a while to show up but it eventually does. And also keeps the resolution. So thanks for all your help. Appreciate it.
PS: If I open the device manager and look at the monitor (EDID override driver) it has a yellow excalamation against it. It says something about another driver in memory and needing a reboot. Error Code 38. A reboot does not change that. But since it does not impact my use of the system I am ignoring it.
