AVS › AVS Forum › Video Components › Home Theater Computers › EDID Override Thread
EDID Override Thread - Page 68
post #2011 of 3078
Originally Posted by Tulli View Post
Should be a problem with the native resolution of the Vizio not being standard HDTV, which is required by the AVR.
I googled and according to []this link[] it is in fact 1366x768.
So there are 2 possible solutions:
1. Use separate connections to the TV and AVR (best solution for 1:1 pixel mapping).
2. Override the EDID so that the preferred resolution is 1280x720.
For option 2 please capture and post the real-time EDID of the Vizio and I'll have a look a it to mod it (see link in my sig. for instructions).
Yes sir, that is in fact my TV, and that is the resolution that (1366x768) is displayed while viewing my HTPC.
I'd love to give "1. Use separate connections to the TV and AVR (best solution for 1:1 pixel mapping)." a shot. How exactly do I go about achieving this? Do I use an HDMI splitter, and have it split the HTPC to the TV and AVR at same time? And that would make the AVR only play the sound from the HTPC?
Thanks for all the help!
post #2012 of 3078
Use a (generic) DVI-HDMI adapter for the second HDMI connection on the DVI port of your Nvidia GTS250. An HDMI splitter won't work as native resolutions/timings are different.
post #2013 of 3078
If audio is "toslink" (S/PDIF)from the splitter, as you mentioned before, that is correct, i. e. 2 channels uncompressed or multichannel compressed audio is the limit for S/PDIF bandwidth.
Otherwise I've added a full audio block ...
Thanks for all your efforts.
In windows i can only select stereo speaker setup. However in applications who support it (like VLC and XBMC) i can select 5.1.
If i find a solution i will post it here, at this point i am just happy i can play the movies i like
cheers
post #2014 of 3078
Thanks for the help. The DVI-HDMI works a bit. I am now able to see my HTPC (just as I did before when it was plugged directly) . Just so far, I am able to hear, youtube, etc., but only on the TV. Nothing from the AVR. I have played around with the playback device settings on the PC, as well as movie player settings, but still unable to hear anything from the AVR.
Oh... YES, the volume is turned up. LOL :P
Any suggestions? Thanks!
post #2015 of 3078
Are the TV and the AVR set in extended mode? Set the AVR to primary and verify that all available audio formats are listed on the "Supported Formats" window of the Nvidia HDMI audio device properties.
Or try connecting the DVI-HDMI cable to the TV and the HDMI to the AVR. Maybe the driver is blocking audio on the DVI port.
Otherwise maybe the Pioneer AVR requires an active video out connection to produce audio. Maybe a "dummy" connection to another free HDMI port on the TV will do.
post #2016 of 3078
Thanks so much for everyone's patience and help with my debacle. I truly appreciate it!!!
As of now, my set up for HTPC is...
HTPC (via dvi-HDMI) > TV
HTPC (via HDMI) > ARV
So, with that said... I believe:
Is already being done... unless I misread?
I will certainly attempt:
... as soon as I get a bit of time and figure out on how to do so. LOL
Thanks again everyone. I truly feel as if I may be missing something so gawd damn simple! It really should not be this difficult! If so, not sure what to blame it on. LOL... TV, HTPC, or AVR! LOL
post #2017 of 3078
I apologize if I sound ignorant but after reading 30 pages I still do not understand how to do this.
I have a Nvidia GTS 450 Video card and the connection map is as follows:
GTS450 >> Pioneer VSX-821-k >> 32LE5300
All of this done with HDMI cables.
I just can not get the image to display nor sound to come out.
Any help?
Attached to this post is the IDs I pulled out using MonInfo
Thank you very much in advance.
PS: Changed the extensions from INF to TXT.
Pioneer.txt 3.013671875k . file
LG TV.Txt 3.00390625k . file
post #2018 of 3078
Any help?
First of all, are you using a mini-HDMI connector/cable? Have you tried with a DVI-HDMI adapter/cable?
post #2019 of 3078
Unfortunately, that's not an option open to me.
I have dualview both on DVI, work purposes, and that's why I am using the mini-HDMI connector.
Sorry for not making this clear in the first post.
post #2020 of 3078
Well, for the record, I could never get the mini-HDMI connection to work 100% with my GTS450. It worked only after boot but then lost connection when switching. But I used an mini-HDMI/HDMI adapter, maybe a mini-HDMI/HDMI cable will work, but I'm not sure.
But AFAIK a GTS450 can only drive up to 2 monitors. For 3 monitors you need a GTX 5xx card.
post #2021 of 3078
Ah, I am not trying to do a triple display system but to be able to switch between my dualview to single TV view through receiver.
I am realizing now I should had given you these details ahead of time, ugh, I swear I did think I was offering all the necessary info.
Once again, I apologize.
post #2022 of 3078
No worries. Try booting the system with the AVR switched to the TV. If you get image try switching to the dual/view input, and then back to the TV. If image is lost then, of course, the mini-HDMI connector is the problem, and the only choice would be trying a mini-HDMI/HDMI cable, if you haven't already.
post #2023 of 3078
I tried the solution number one you offered, try to connect through the mini HDMI and then restart the PC while the Receiver and TV are on to no avail.
I have found a way to force it to appear in the TV but then the resolution is all messed up and can't get it corrected nor the sound comes through the mini HDMI.
Any other recommendations please?
post #2024 of 3078
A mini-HDMI/HDMI cable (no mini HDMI/HDMI adapter), but I'm not sure that it'll really work.
post #2025 of 3078
Hi Tulli. I've recently upgraded my TV and wondered if you could insert the 8-LPCM SAD and combine with my new TV.
I would really appreciate any assistance.
Samsung LA40D550 HT-R380.zip 2.5859375k . file
post #2026 of 3078
Samsung LA40D550 - ONKYO HTR-380.zip 1.2802734375k . file
post #2027 of 3078
Hi
Cant get audio from nvidia gtx when connected to yamaha rx-a810 receiver and benq w600.
Using Nvidia 3d vision configuration with emitter and nvidia 3d glasses . Monitor driver has been replaced with 'Acer H5360 (EDID Override) to get nvidia supported 3d display.
Any solutions?
post #2028 of 3078
Originally Posted by me_21 View Post
Hi
Any solutions?
The EDID override that you're using is the problem. I would recommend separate connections to the proj. and the AVR. Otherwise a proper merge of the real-time EDIDs of the proj. and the AVR is required. I can help you with this but I need the real-time EDID of the W600 to do the mod (see instructions in my sig.).
post #2029 of 3078
Thanks for your help.Running separate feeds from the two dvi feeds has solved the problem.
post #2030 of 3078
Thanks for this Tulli. Unfortunatey, I still don't seem to be able to send 8 channels to my AVR. Anything over 5.1 comes out as stereo. Any idea what the issue could be?
post #2031 of 3078
Okay, after skimming through the past 60 pages of this, I kinda know what's going on. My video is fine, but I can't get 5.1 audio out to my receiver. Here's what I have:
[HTPC w/ GeForce GT 430] --HDMI--> [Sony BDV-E750W Home Theater System] --HDMI--> [Sony KDL-46EX700]
Easy setup with just HDMI cables. I used MonInfo to save the EDID of the TV and Receiver to inf, but still not sure how to edit these and set them as the display driver so the graphics card will bitstream 5.1 to the receiver. I uploaded the EDID info for both TV and receiver, if anyone can point me in the right direction on what to do next.
Sony BDV-E750W.zip 1.228515625k . file
Sony KDL-46EX700.zip 1.25390625k . file
post #2032 of 3078
According to EDID of Sony BDV-E750W you have 5.1 AC3 and DTS capability. Check that these formats are listed for the HDMI audio device (Under "Supported Formats").
Just keep in mind that 2 channels for the HDMI audio device applies only to uncompressed audio (LPCM), which is the maximum for S/PDIF bandwidth. But 5.1 compressed audio should work. Of course the application audio must be set to output uncompressed audio. If it's with games look for a cheap audio card that does live DD or DTS encoding.
post #2033 of 3078
Thanks for the response. I'm using my HTPC for movies and TV shows mainly. HD MKV's and BluRay ISO's. Not really playing games on it. In the windows sound control panel, normally where you'd be able to select 5.1 surround, 7.1 surround, etc. the only option is stereo:
When I try and test the speakers using a surround sound media file, the front right, center and left play correctly. The rear left and right play through the front left and right. I think even though the graphics card is connected directly to the receiver, it's still reading the EDID from the TV. I've re-installed windows a number of times with the same effect and all of my drivers are up to date. Do you think this could be the issue?
post #2034 of 3078
here is my driver for hd33 and receiver
hd33.txt 3.005859375k . file
ht-r390.txt 3.013671875k . file
post #2035 of 3078
That is fine, if you followed my explanation. You must check the "Supported Formats" tab under properties and see that Dolby Digital is listed. Then set your video player to send a compressed AC3 audio stream. Again, there is no way to send a multichannel uncompressed audio stream over S/PDIF, only "stereo" (2 channels LPCM).
post #2036 of 3078
Tulli, you seem to know what you're doing and I was hoping you could help me.
HDTV/Monitor: Vizio vf550m
Sound System: Logitech z5500
Graphics Card: GeForce 210
Hoping for ac3 dts ect..
Was also wondering how to identify the values that need to be changed and what to change them to on other displays I may encounter in the future? How do you work your magic?
Will Attach Visio moninfo inf.
ForestKlown
Vizio.zip 1.2021484375k . file
post #2037 of 3078
ForestKlown
Best/simplest solution is S/PDIF out to your speakers. No need of messing up with EDID editing. EDID overrides are only required when there's a problem with EDID detection. Besides, the Vizio EDID shows no AC3/DTS capabilities.
post #2038 of 3078
The thing is, I use to have a 9600gt that had a physical s/pdif passthrough port of which I hooked up a cable to my mobo s/pdif internal header. It worked great, would send dts and ac3 to my sound system through my tv. Then the video card failed and I bought this 210 that has an onboard audio chip which won't let me do this.
I've gotten my bluray player, cable receiver, and xbox to work without a hitch. Is there no way to make this happen?
ForestKlown
post #2039 of 3078
Here's my setup:
HTPC with nVidia GT430=>Onkyo TX-NR609=>50" LG 720p Plasma, all HDMI connections under 6 feet
The problem I'm experiencing is an odd one. When I play games or browse the web, the video on the LG is perfect. When I try to play tv (Ceton InfiniTV4) or watch a blu-ray, the screen displays the image, but moved over ~10%, with a black bar to the right. If I turn off the receiver, then turn it back on, it fixes the problem with TV, but not with BluRays (stops playback and says that the system isn't HDCP compliant).
Troubleshooting I've tried:
Updated firmware on AVR and drivers/software on GT430--no improvement
Connected GT430=>LG plasma via HDMI--worked perfectly, no image shift.
Called Onkyo to see if there's a setting I don't know of--that was fruitless and caused me to reset my receiver's firmware for no good reason.
The reason I'm thinking it is something to do with EDID is because it's only when dealing with HDCP sources, so I think the system is checking something and getting a bad value in response, then adjusting the viewable portion in response.
Is this related to EDID? This issue is causing my wife to doubt my HTPC project, and it's otherwise a wonderfully fast machine (I'll post full specs in the show your build thread when I've finalized the SATA wires and zip-tied it all) that I'm sure will last for years.
post #2040 of 3078
ForestKlown
OK, try the attached EDID override. As always, 2 channels applies only to LPCM. Just set your application to send a compressed audio stream.
Vizio vf550m + 5.1(AC3&DTS).zip 1.25390625k . file
