Mentioned my my configuration problems on a different thread and was told a HDMI Detective may work, but want to find out first before I make a decent investment. Anyone with any input?
I am unable to get a connection from my Toshiba Thrive tablet (HDMI out at 720p) to my Optoma EP910 projector (HDCP compliant, native resolution 1400 x 1050, with supported 720p resolution) via HDMI to DVI cable. And also not able to do this with a Denon AVR391 receiver added in the desired chain (tablet - HDMI cable - receiver - HDMI to DVI cable - projector).
The HDMI port works fine on the Toshiba Thrive outputting to receiver and display set-ups when only HDMI is used, and will output audio to my receiver if the projector is not being output. But, as soon as the projector is plugged in, all audio is lost and no video is displayed. Point is I can output video to HDMI displays, but have never once been able to output video to this DVI display.
I have a laptop existing in the set-up and have no issues outputting via HDMI to the receiver to the projector at 1600x900; if the projector is off, the audio still will play through the receiver. If the receiver is off, the audio will play through the laptop speakers.
My question is, is if I add the HDMI Detective to the chain for the tablet (tablet - HDMI cable - HDMI Detective - HDMI cable - receiver - HDMI to DVI cable - projector) will this solve my issue of sending audio and video to the HDMI receiver and DVI projector?
Thanks, anyway. I like that projector a lot, but might convince me to upgrade.
