Ok here it is with the full area on the right panel.
Monitor
Model name............... RX-V863
Windows description...... Generic PnP Monitor
Manufacturer............. Yamaha
Plug and Play ID......... YMH312B
Serial number............ n/a
Manufacture date......... 2008, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (Reserved - 0x00)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-91kHz
Vertical scan range...... 23-121Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Standard timings supported
Report information
Date generated........... 22/12/2008
Software revision........ 2.11.0.760
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,65,A8,2B,31,00,00,00,00,00,12,01,03, 80,00,00,78,0A,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80, C4,8E,21,00,00,9E,00,00,00,FC,00,52,
......................... 58,2D,56,38,36,33,0A,20,20,20,20,20,00,00,00,FD,00,17,79,0F, 5B,0F,00,0A,20,20,20,20,20,20,01,60
Will re run it and put the report on tomorrow am.
