AVS › AVS Forum › Video Components › Home Theater Computers › EDID Override Thread
EDID Override Thread - Page 75
post #2221 of 3084
as you see in this Picture there are added "coded formats" (DTS Audio and Dolby Digital, in the red box at the bottom), but in the red box at the top you see that "maximal ammounts of channels" is still 2.
and in the Speaker Setup i can still just choose Stereo (red box in Picture 2)
"Moninfo" is still showing 2 Channels, after installing the new driver.
[IMG=http://imageshack.us/a/img837/341/unbenannt3y.jpg][/IMG]
Is there anyway to help me out, or is that hopeless?
anyway thank you very much for your support and patience
Greetz
Martinho
post #2222 of 3084
Just forget everything i wrote redface.gif)
With Media Player Classic it works !
Yeeeeeehaaaaaaaaaa!!!!
Thank you so much men!!!!
You are Great!!
post #2223 of 3084
I'm looking for a point in the right direction. I initially thought I was having drivers issues due to the incredibly bad ATI drivers for my recent computer build (12.6, 12.7, 12.8 none work well; currently on 12.8).
I run a Win7 64bit OS with an XFX radeon HD 7970 video card on a ASUS P8Z77V Deluxe motherboard that is supposed to support the lossless codecs of my BR and HD DVD collections with no down sampling in the processing chain at bit rates up to 192kHz. If I was just using integrated graphics on my i7-3770k and the hdmi out of the motherboard I doubt I'd have issues, though I have not tested it.
My preferred setup is PC - Yamaha RX-V3900 - LG 46' LE5400.
I plan to bitstream audio to the receiver for decoding (though I'll need a software solution as the free powerdvd10 bundled with my BR drive only supports LPCM; which is fine for now). Since I'm fairly certain I get better video processing with the 7970, I have HDMI set to passthrough on the receiver with no scaling. Audio is set to amp, not amp-tv.
My initial issues were the usual video drop outs when switching between inputs and devices and the 10% underscan reset in CCC. However, now the PC will not even boot correctly unless I'm directly connected to my monitor (probably the biggest concern is that there are system errors, blue screens, or other odd behavior that doesn't allow win7 to boot properly when connected to the receiver). Due to this issue, I can no longer start the computer connected to the receiver; I have to connect to the tv directly, boot, and then swap the hdmi cable from the PS3 after booting up. While this worked a few times, it was a pain. Now, after the cable swap I no longer get audio...it appears to be a handshake issue that causes a constant switching loop and the amp won't select an audio format. Is it possible it's as basic as a conflict between the realtek hd audio drivers and the 12.8 catalyst drivers? Though I've installed it, no realtek ATI HDMI driver appears under device manager (I'm sure it used to; may also be integrated into 12.8).
When I ran MonInfo I also got this odd result:
Model name............... LG TV
Windows description...... Generic PnP Monitor LG TV
Manufacturer............. LGE
Plug and Play ID......... GSM0001
Serial number............ n/a
Manufacture date......... 2010, ISO week 1
Filter driver............ Monitor
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7.2 in)
Power management......... Not supported
Extension blocs.......... 1 (Unknown - 0x00)result:
The monitor is 46 or 48' yet registers only 7.2 inches! Connected directly, native resolution is 1920x1080p. When I ran it again through the receiver I get "Native/preferred timing.. 1280x720p at 60Hz (16:9)." This is odd b/c the receiver should also show 1920x1080p.
I guess my question is whether these problems sounds familiar to anyone? I'm willing to try the EDID override, (or the Gefen HDMI detective, if I have too, ugh) but the thread seems to apply mainly to denon, onkyo and sony receivers (though the initial post by RandomFoe was a Yamaha rx-v series receiver and plenty more show up in the thread). If the override still works for Yamaha can someone please let me know or link to an .inf file that has worked for them?
Update- Tried one of Tulli's .inf's for a similar LG and had no luck. I've rolled it back and will probably need to clean the registry now since it still sees the yamaha as a denon. I posted this in it's own tread and got nowhere, so I'm hoping this thread will work.
post #2224 of 3084
I've made progress. I booted through the receiver, which is huge. I discovered I was missing an "SM bus controller driver" that didn't install with the rest of the mobo chipset drivers. Once installed, it booted. It boots differently, as I get a green bar with Microsoft, rather than the ASUS bios splash screen that allows me to go into the bios and the conventional windows logo that forms. I don't care for now, but this is strange since the bios are set to show the ASUS logo b/c it makes accessing the bios so simple.
I got the new realtek driver for the mobo from ASUS. It seemed to help as audio is now flowing to the Yamaha intermittently, but there is still a conflict, as audio cuts in and out about every 2 seconds. AVR still shows up as denon after the rollback, which also strikes me as odd.
I still think an EDID override may help since my problems are identical to the issues experienced by everyone in the forum, though driver conflicts are a possible cause.
post #2225 of 3084
Try using only the native AMD HDMI audio driver (no Realtek). The video problems are exclusively due to the AMD driver though. Can you disable the onboard video, at least for troubleshooting?
post #2226 of 3084
Tulli, thank you for responding...
The on board iGPU video has always been disabled. In fact, as part of my troubleshooting yesterday, I enabled both the pci-e and iGPU graphics to see what would happen. Once enabled, I got a message from the device manager that I was missing video controller. I Installed the most recent intel drivers from ASUS, and the 7970 and Intel 4000 graphics both show up as display adapters.
When both the mobo and 7970 were connected simultaneously I saw multiple devices, instead of just one, but windows viewer showed the Yamaha was disconnected (and still seeing Denon after clearing the Reg with glary utilities). Moninfo still shows the Denon info too...and a few other suspect devices.
I continued to use the mobo HDMI all night and it worked. The color was less accurate, but it had no glitches. The pc went in to sleep mode, the tv did a power save and shut off, and no reconfig was required. I don't want to do a work around, but I'm considering a (7970 - TV) and (mobo HDMI - receiver) dual cable set up if all else fails.
Should I download a screen capture app and attach some shots of what I'm seeing? I could get some shots with iGPU enabled/disabled, etc... I'm still confused by the monitor showing up tablet sized too...seems the EDID info is corrupted and I only confused things by installing the .inf.
post #2227 of 3084
Have you already tried the cleaning procedure in section 4 in my sig.? There really seems to be some corruption of monitor drivers in the registry.
post #2228 of 3084
Not yet, was too giddy I had a base level of functionality and just watched some TV.
I'll go through the steps tonight and let you know.
post #2229 of 3084
@Tulli
Hi! I have exactly the same problen as MartinhoSt. Maybe you can do the edid-override for my setup too smile.gif
the facts:
-Win 7 64
-ATI Mobility Radeon HD 4550
-HDMI -> Philips 7603 LCD -> coaxial digital output to -> 5.1 System
I only got 2.0 in the "Realtek HDMI Output", but I want 5.1.
Here is my "inf."-File I created with MonInfo:
monitor.zip 1k .zip file
I hope you can help me!
THX!
greetings, matt
post #2230 of 3084
2 channels = 2 LPCM (uncompressed audio stream), which is the max bandwidth over S/PDIF. You only need to set your application to send an AC3 (compressed) audio stream to get multichannel.
post #2231 of 3084
@Tulli
Thanks for your answer!
I tried divX Movies with 5.1 AC3 using the vlc Player. In the vlc-player i used this settings:
But my 5.1 System says its Stereo and uses ProLogic2. When I connect my XBox 360 to the same HDMI-Port, the AVR recognizes DD 5.1 and works fine. Thats why I wanted to tell Windows by using edid override, that the tv can handle 5.1. So i could turn on 5.1 in the windows/Realtek audio-settings, right?
post #2232 of 3084
Should be a setup problem in VLC. Just googled and found this (I don't use VLC). And this (this is closer to your version of VLC I guess).
post #2233 of 3084
using "Win32 waveOut extension output" instead of "DirectX audio output" had no effect. With other players I have also no 5.1 with my AVR.
post #2234 of 3084
The native EDID of the monitor is fine, but see if the mod makes a difference. It has a 6 speakers descriptor, so maybe it helps, but the override will still give you 2 (LPCM) channels for Windows. Again this is correct for LPCM over S/PDIF..
monitor+AC3+DTS+6Spkrs.zip 1k .zip file
post #2235 of 3084
hi,
Somthing about my setup:
AVR : Pioneer VSX-2020
Beamer : Epson EH-TW6000W
I've got some problems with playing 3D files. the software to play the 3d files is PowerDVD.
If i connect the Beamer directly to my laptop there is no problem.
But if i connect the Laptop to the AVR and want to chose a 3D Mode , power dvd says that the current display doesn't support the 3d format.
i think this is the right mode. With the epson directly on laptop the auto detection works perfectly.
Should i merge the two .inf files !?
How ? Can someone help me please ?
The data if the epson is connected directly to the laptop :
Code:
Monitor
  Model name............... EPSON PJ
  Windows description...... PnP-Monitor (Standard) EPSON PJ
  Manufacturer............. Samsung
  Plug and Play ID......... SECA600
  Manufacture date......... 2008, ISO week 18
  Filter driver............ None
  Input signal type........ Analog 0.700,0.300 (1.0V p-p)
  Sync input support....... Separate, Composite, Sync-on-green
  Screen size.............. Undefined or variable
  Extension blocs.......... None
  DDC/CI................... n/a
Color characteristics
  Default color space...... sRGB
  Display gamma............ 2,20
  Red chromaticity......... Rx 0,640 - Ry 0,329
  Green chromaticity....... Gx 0,300 - Gy 0,600
  Blue chromaticity........ Bx 0,149 - By 0,060
  White point (default).... Wx 0,313 - Wy 0,328
  Additional descriptors... None
Timing characteristics
  Range limits............. Not available
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1280x800p at 60Hz
    Modeline............... "1280x800" 83,500 1280 1352 1480 1680 800 803 809 831 -hsync +vsync
  Detailed timing #1....... 1440x900p at 60Hz
    Modeline............... "1440x900" 106,500 1440 1520 1672 1904 900 903 909 934 -hsync +vsync
  Detailed timing #2....... 1680x1050p at 60Hz
    Modeline............... "1680x1050" 146,250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Standard timings supported
     720 x  400p at  70Hz - IBM VGA
     720 x  400p at  88Hz - IBM XGA2
     640 x  480p at  60Hz - IBM VGA
     640 x  480p at  67Hz - Apple Mac II
     640 x  480p at  72Hz - VESA
     640 x  480p at  75Hz - VESA
     800 x  600p at  56Hz - VESA
     800 x  600p at  60Hz - VESA
     800 x  600p at  72Hz - VESA
     800 x  600p at  75Hz - VESA
     832 x  624p at  75Hz - Apple Mac II
    1024 x  768i at  87Hz - IBM
    1024 x  768p at  60Hz - VESA
    1024 x  768p at  70Hz - VESA
    1024 x  768p at  75Hz - VESA
    1280 x 1024p at  75Hz - VESA
    1152 x  870p at  75Hz - Apple Mac II
    1280 x  960p at  85Hz - VESA STD
    1600 x 1200p at  60Hz - VESA STD
    1280 x 1024p at  85Hz - VESA STD
    1280 x  720p at  85Hz - VESA STD
    1152 x  864p at  75Hz - VESA STD
    1024 x  768p at  85Hz - VESA STD
     800 x  600p at  85Hz - VESA STD
     640 x  480p at  85Hz - VESA STD
Report information
  Date generated........... 03.10.2012
  Software revision........ 2.60.0.972
  Data source.............. Registry
  Operating system......... 6.1.7601.2.Service Pack 1
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,A3,00,A6,01,01,01,01,12,12,01,03,1E,00,00,78,0E,DE,50,A3,54,4C,99,26,
  0F,50,54,FF,FF,80,81,59,A9,40,81,99,81,D9,71,4F,61,59,45,59,31,59,9E,20,00,90,51,20,1F,30,48,80,
  36,00,00,00,00,00,00,1C,9A,29,A0,D0,51,84,22,30,50,98,36,00,00,00,00,00,00,1C,21,39,90,30,62,1A,
  27,40,68,B0,36,00,00,00,00,00,00,1C,00,00,00,FC,00,45,50,53,4F,4E,20,50,4A,20,20,20,20,0A,00,7F
Code:
Monitor
  Plug and Play ID......... SECA50A
  Manufacture date......... 2011, ISO week 39
  Screen size.............. 1600 x 900 mm (72,3 in)
  Horizontal scan range.... 15-68kHz
  Vertical scan range...... 24-61Hz
  Video bandwidth.......... 150MHz
  CVT standard............. Not supported
  Native/preferred timing.. 1920x1080p at 60Hz (16:9)
    Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
  Detailed timing #1....... 1920x1080i at 60Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Report information
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,A3,0A,A5,01,01,01,01,27,15,01,03,80,A0,5A,78,0E,DE,50,A3,54,4C,99,26,
  0F,50,54,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
  45,00,40,84,63,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,84,63,00,00,9E,00,00,00,FD,00,18,
  3D,0F,44,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,45,50,53,4F,4E,20,50,4A,0A,20,20,20,20,01,EE
The data of the Pioneer VSX-2020:
Code:
Monitor
  Model name............... VSX-2020
  Manufacturer............. Pioneer
  Plug and Play ID......... PIO0000
  Manufacture date......... 2010, ISO week 0
  Extension blocs.......... 1 (CEA-EXT)
  DDC/CI................... Not supported
EIA/CEA-861 Information
  Revision number.......... 3
  IT underscan............. Supported
  Basic audio.............. Supported
  YCbCr 4:4:4.............. Supported
  YCbCr 4:2:2.............. Supported
  Native formats........... 2
  Detailed timing #1....... 1280x720p at 60Hz (16:9)
    Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
    1920 x 1080p at  60Hz - HDTV (16:9, 1:1) [Native]
    1920 x 1080p at  50Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  24Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  60Hz - HDTV (16:9, 1:1)
    1920 x 1080i at  50Hz - HDTV (16:9, 1:1)
    1280 x  720p at  60Hz - HDTV (16:9, 1:1)
    1280 x  720p at  50Hz - HDTV (16:9, 1:1)
     720 x  480p at  60Hz - EDTV (16:9, 32:27)
     720 x  480p at  60Hz - EDTV (4:3, 8:9)
     720 x  576p at  50Hz - EDTV (16:9, 64:45)
     720 x  576p at  50Hz - EDTV (4:3, 16:15)
     720 x  480i at  60Hz - Doublescan (16:9, 32:27)
     720 x  480i at  60Hz - Doublescan (4:3, 8:9)
     720 x  576i at  50Hz - Doublescan (16:9, 64:45)
     720 x  576i at  50Hz - Doublescan (4:3, 16:15)
     640 x  480p at  60Hz - Default (4:3, 1:1)
    1440 x  480p at  60Hz - DVD (16:9, 16:27)
    2880 x  480p at  60Hz - Console (16:9, 8:27)
    1440 x  480p at  60Hz - DVD (4:3, 4:9)
    2880 x  480p at  60Hz - Console (4:3, 2:9)
    1440 x  576p at  50Hz - DVD (16:9, 32:45)
    2880 x  576p at  50Hz - Console (16:9, 16:45)
    1440 x  576p at  50Hz - DVD (4:3, 8:15)
    2880 x  576p at  50Hz - Console (4:3, 4:15)
    2880 x  480i at  60Hz - Console (16:9, 8:27-80:27)
    2880 x  480i at  60Hz - Console (4:3, 2:9-20:9)
    2880 x  576i at  50Hz - Console (16:9, 16:45-160:45)
    2880 x  576i at  50Hz - Console (4:3, 2:15-20:15)
    NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
  LPCM    8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
  AC-3    6-channel,  640k max. bit rate at 32/44/48 kHz
  DTS     7-channel, 1536k max. bit rate at 44/48/88/96 kHz
  SACD    6-channel                      at 44 kHz
  DD+     8-channel                      at 44/48 kHz
  DTS-HD  8-channel, 16-bit              at 44/48/88/96/176/192 kHz
  DVD-A   8-channel                      at 44/48/88/96/176/192 kHz
CE speaker allocation data
  Channel configuration.... 7.1
  Front left/right......... Yes
  Front LFE................ Yes
  Front center............. Yes
  Rear left/right.......... Yes
  Rear center.............. No
  Front left/right center.. No
  Rear left/right center... Yes
  Rear LFE................. No
CE vendor specific data (VSDB)
  IEEE registration number. 0x000C03
  CEC physical address..... 3.4.0.0
  Supports AI (ACP, ISRC).. Yes
  Supports 48bpp........... No
  Supports 36bpp........... Yes
  Supports 30bpp........... Yes
  Supports YCbCr 4:4:4..... Yes
  Supports dual-link DVI... No
  Maximum TMDS clock....... 150MHz
  Video latency (p)........ 125ms
  Audio latency (p)........ 125ms
  Video latency (i)........ 125ms
  Audio latency (i)........ 125ms
  HDMI video capabilities.. Yes
  EDID screen size......... No additional info
  3D formats supported..... Not supported
  Data payload............. 030C003400B81EE03F3F3F3F8000
CE video capability data
  CE scan behavior......... Supports overscan and underscan
  IT scan behavior......... Always underscanned
  PT scan behavior......... Supports overscan and underscan
  RGB quantization range... Selectable (via AVI YQ)
  YCC quantization range... Selectable (via AVI YQ)
CE colorimetry data
  xvYCC709 support......... No
  xvYCC601 support......... No
  sYCC601 support.......... No
  AdobeYCC601 support...... No
  AdobeRGB support......... No
  Metadata profile flags... 0x00
Report information
  Data source.............. Real-time 0x0041
Raw data
  00,FF,FF,FF,FF,FF,FF,00,41,2F,00,00,01,01,01,01,00,14,01,03,80,A0,5A,78,0E,DE,50,A3,54,4C,99,26,
  3D,0F,44,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,56,53,58,2D,32,30,32,30,0A,20,20,20,20,01,91,
  02,03,57,F2,5C,90,1F,20,05,14,04,13,03,02,12,11,07,06,16,15,01,0F,24,0E,23,1E,26,1D,25,0B,0A,1A,
  19,3B,09,7F,07,0F,7F,07,15,07,50,3E,1E,C0,4D,02,00,57,06,00,5F,7E,01,67,7E,00,77,1F,03,83,4F,00,
  00,6E,03,0C,00,34,00,B8,1E,E0,3F,3F,3F,3F,80,00,E2,00,FB,E3,05,00,00,01,1D,00,72,51,D0,1E,20,6E,
  28,55,00,40,84,63,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,3C
Code:
Monitor
  Windows description...... PnP-Monitor (Standard) VSX-2020
Report information
  Data source.............. Registry-Active
Raw data
post #2236 of 3084
Post the Epson full 256-bytes real-time (not registry) EDID for a mod.
post #2237 of 3084
sorry..
Realtime:
Only the 3D capabillity should be modded..
Sound works fine over the VSX.
Thank you !
Code:
Monitor
  Native formats........... 3
  LPCM    2-channel, 16/20/24 bit depths at 32/44/48 kHz
  Channel configuration.... 2.0
  Front LFE................ No
  Front center............. No
  Rear left/right.......... No
  Rear left/right center... No
  CEC physical address..... 3.0.0.0
  Data payload............. 030C003000B81EE03F3F3F3FC00401000063
CE colorimetry data
Report information
Raw data
  3D,0F,44,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,45,50,53,4F,4E,20,50,4A,0A,20,20,20,20,01,EE,
  02,03,37,F3,50,90,1F,20,05,14,04,13,03,02,12,11,07,06,16,15,01,23,09,07,07,83,01,00,00,72,03,0C,
  00,30,00,B8,1E,E0,3F,3F,3F,3F,C0,04,01,00,00,63,E3,05,00,00,E2,00,FB,01,1D,00,72,51,D0,1E,20,6E,
  28,55,00,40,84,63,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,F4
post #2238 of 3084
Why is :
" 3D formats supported..... Not supported "
when it works fine ?
hm..
post #2239 of 3084
TV's typically will not pass AC3 through from any connection except the built in TV tuner. MartinhoST is the first report I have seen that will do it.
post #2240 of 3084
Originally Posted by somebuddy View Post
Why is :
hm..
No idea, really. Here's your mod.
Epson EH-TW6000W - PIONEER VSX-2020.zip 1k .zip file
post #2241 of 3084
Is it possible to add 3D Support manually ?
Edited by somebuddy - 10/3/12 at 10:42am
post #2242 of 3084
Maybe a driver problem with the WifiHD Transmitter ?
post #2243 of 3084
It should work. The only difference between the native Epson EDID and the mod is the Pioneer audio descriptor. Did you boot up after installing the override?
post #2244 of 3084
yes of course.. i robooted twice..
This is ne new realtime data which i can readout when the vsx is connected :
Code:
Monitor
CE colorimetry data
Report information
Raw data
post #2245 of 3084
That's the real-time EDID.
Ah! But I forgot to ask: what's your graphic adapter? If it's an Intel IGP (I'm not sure about IVB 4000) then it won't accept EDID overrides.
post #2246 of 3084
so there is no chance ?
post #2247 of 3084
Not with an EDID override. The Pioneer EDID looks OK so maybe it's a PDVD issue. Can you try a different software (e.g. TMT5)?. If the problem persists then it would be a driver issue.
post #2248 of 3084
Hi Tulli ! I have exactly the same problem as MartinhoSt. Maybe you can do the edid-override for my setup too.
My system:
-Win 7 32
-Nvidia gforce 460
-HDMI -> samsung UE40ES7000 LCD -> optical digital output to -> 5.1 System
I only got 2.0 channels and no dolby digital and dts Audio in the coded formats, can you please make me an override EDID so i can get these 2 coded formats to be accepted?
realtime Code:
Code:
Monitor
 Model name............... SAMSUNG
  Plug and Play ID......... SAM090B
  Serial number............ 1
  Manufacture date......... 2011, ISO week 42
  Screen size.............. 890 x 500 mm (40,2 in)
  Default color space...... Non-sRGB
  Red chromaticity......... Rx 0,640 - Ry 0,330
  Blue chromaticity........ Bx 0,150 - By 0,060
  White point (default).... Wx 0,313 - Wy 0,329
  Horizontal scan range.... 15-81kHz
  Vertical scan range...... 24-75Hz
  Video bandwidth.......... 230MHz
  Detailed timing #1....... 1366x768p at 60Hz (16:9)
    Modeline............... "1366x768" 85,500 1366 1436 1579 1792 768 771 774 798 +hsync +vsync
    1280 x  720p at  60Hz - VESA STD
    1280 x  800p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1440 x  900p at  60Hz - VESA STD
    1600 x  900p at  60Hz - VESA STD
    1680 x 1050p at  60Hz - VESA STD
  Native formats........... 1
  Detailed timing #1....... 1920x1080i at 50Hz (16:9)
    Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
  Detailed timing #2....... 1920x1080i at 60Hz (16:9)
  Detailed timing #3....... 1280x720p at 50Hz (16:9)
    Modeline............... "1280x720" 74,250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
  Detailed timing #4....... 1280x720p at 60Hz (16:9)
    1920 x 1080p at  25Hz - HDTV (16:9, 1:1)
    1920 x 1080p at  30Hz - HDTV (16:9, 1:1)
  IT scan behavior......... Supports overscan and underscan
  PT scan behavior......... Not supported
  RGB quantization range... Not supported
  YCC quantization range... Not supported
CE colorimetry data
  xvYCC709 support......... Yes
  xvYCC601 support......... Yes
  Metadata profile flags... 0x01
  CEC physical address..... 2.0.0.0
  Maximum TMDS clock....... 225MHz
  Audio/video latency (p).. n/a
  Audio/video latency (i).. n/a
  EDID screen size......... Rounded to nearest cm
  3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
  3D formats supported..... Mandatory formats plus some primary VICs
  Data payload............. 030C002000B82D21D0080140073F405090A0
Report information
  Date generated........... 04-10-2012
  Data source.............. Real-time 0x0051
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,2D,0B,09,01,00,00,00,2A,15,01,03,80,59,32,78,0A,EE,91,A3,54,4C,99,26,
  0F,50,54,BD,EF,80,71,4F,81,C0,81,00,81,80,95,00,A9,C0,B3,00,01,01,02,3A,80,18,71,38,2D,40,58,2C,
  45,00,A0,5A,00,00,00,1E,66,21,56,AA,51,00,1E,30,46,8F,33,00,A0,5A,00,00,00,1E,00,00,00,FD,00,18,
  4B,0F,51,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,9B,
  02,03,34,F1,4D,90,1F,04,13,05,14,03,12,20,21,22,07,16,23,09,07,07,83,01,00,00,E2,00,0F,E3,05,03,
  01,72,03,0C,00,20,00,B8,2D,21,D0,08,01,40,07,3F,40,50,90,A0,01,1D,80,D0,72,1C,16,20,10,2C,25,80,
  A0,5A,00,00,00,9E,01,1D,80,18,71,1C,16,20,58,2C,25,00,A0,5A,00,00,00,9E,01,1D,00,BC,52,D0,1E,20,
  B8,28,55,40,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,00,00,00,96
Lanzinha
Edited by lanzinha - 10/4/12 at 3:19am
post #2249 of 3084
post #2250 of 3084
Hi,
I solved the problem !
My Dell Vostro 3550 has a switchable GPU. So i could assign PowerDVD12 to the much better ATI Radeon GPU. After this, power dvd accept your .inf and works perfectly !
Thanks for you work !
MTM5 doesn't allow any 3D options. All 3D options are "greyed out".
