Tulli,
Okay, after a week I was able to sit down and go through point 4 on your list. I uninstalled the 6 to 8 additional monitors that showed up. They no longer show up in device mgr, but the following is still there under playback devices:
None of the new audio formats show up as supported any longer. I am still bypassing the 7970 and using the iGPU for all info. I have not deleted Realtek...yet.
I am connected through the receiver currently. Some formats appear supported below, but lots of other strange monitor/receiver info from Moninfo (again this is a 46-48" monitor, not a tablet):
Monitor
Model name............... LG TV
Manufacturer............. LGE
Plug and Play ID......... GSM0001
Serial number............ n/a
Manufacture date......... 2010, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 31-82kHz
Vertical scan range...... 57-63Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
800 x 600p at 60Hz - VESA STD
640 x 480p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 4
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #3....... 1920x1080p at 24Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 480p at 60Hz - DVD (16:9, 16:27)
2880 x 480p at 60Hz - Console (4:3, 2:9)
2880 x 480p at 60Hz - Console (16:9, 8:27)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
DTS 7-channel, 1536k max. bit rate at 32/44/48/88/96 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DVD-A 8-channel at 48/96/192 kHz
DTS-HD 8-channel, 16-bit at 48/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. Yes
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 030C001000B82D00
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
Report information
Date generated........... 10/11/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0061
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,1E,6D,01,00,01,01,01,01,01,14,01,03,80,10,09,78,0A,EE,91,A3,54,4C,99,26,
0F,50,54,A1,08,00,81,80,61,40,45,40,31,40,01,01,01,01,01,01,01,01,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,A0,5A,00,00,00,1E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,A0,5A,00,00,00,18,00,00,00,FD,00,39,
3F,1F,52,10,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,47,20,54,56,0A,20,20,20,20,20,20,20,01,AC,
02,03,39,F4,4A,10,20,05,84,03,02,0E,0F,23,24,38,09,7F,07,0F,7F,07,15,07,50,3E,1F,C0,4D,02,00,57,
06,00,67,54,00,5F,54,01,83,5F,00,00,68,03,0C,00,10,00,B8,2D,00,E3,05,03,01,01,1D,80,18,71,1C,16,
20,58,2C,25,00,A0,5A,00,00,00,9E,02,3A,80,18,71,38,2D,40,58,2C,45,00,A0,5A,00,00,00,1E,01,1D,80,
3E,73,38,2D,40,7E,2C,45,80,C4,8E,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,AF
Monitor
CE colorimetry data
Report information
Raw data
