Hi Kemac, you are right, it does work with the original file in the first post... now what did I do wrong...
here is what moninfo gives me when connected directly in my TV:
Monitor
Model name............... Panasonic-TV
Windows description...... Generic PnP Monitor
Manufacturer............. Panasonic
Plug and Play ID......... MEIA07C
Serial number............ n/a
Manufacture date......... 2008, ISO week 0
Filter driver............ monitor
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.345
Green chromaticity....... Gx 0.291 - Gy 0.635
Blue chromaticity........ Bx 0.163 - By 0.093
White point (default).... Wx 0.288 - Wy 0.296
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (4:3)
Detailed timing #4....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #5....... 1440x480i at 60Hz (4:3)
CE video data (timings supported)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 190MHz
Report information
Date generated........... 1/1/2009
Software revision........ 2.20.0.779
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,34,A9,7C,A0,01,01,01,01,00,12,01,03, 80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
......................... 17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,02,3A,80,18,71,38,2D,40,58,2C,
......................... 45,00,BA,88,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, BA,88,21,00,00,9E,00,00,00,FC,00,50,
......................... 61,6E,61,73,6F,6E,69,63,2D,54,56,0A,00,00,00,FD,00,17,3D,0F, 44,0F,00,0A,20,20,20,20,20,20,01,FF,
......................... 02,03,1E,71,49,90,05,20,04,03,02,07,06,01,23,09,07,01,67,03, 0C,00,10,00,B8,26,E3,05,03,01,01,1D,
......................... 00,72,51,D0,1E,20,6E,28,55,00,BA,88,21,00,00,1E,8C,0A,D0,8A, 20,E0,2D,10,10,3E,96,00,BA,88,21,00,
......................... 00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,0B,88,21,00,00,18, 8C,0A,A0,14,51,F0,16,00,26,7C,43,00,
......................... BA,88,21,00,00,98,8C,0A,A0,14,51,F0,16,00,26,7C,43,00,0B,88, 21,00,00,98,00,00,00,00,00,00,00,BC
and here is what I get when plugged directly to the yamaha rx-v863:
Monitor
Model name............... RX-V863
Manufacturer............. Yamaha
Plug and Play ID......... YMH312B
Extension blocs.......... 1 (Reserved - 0x00)
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Horizontal scan range.... 15-91kHz
Vertical scan range...... 23-121Hz
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Report information
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,65,A8,2B,31,00,00,00,00,00,12,01,03, 80,00,00,78,0A,0D,C9,A0,57,47,98,27,
......................... 12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80, C4,8E,21,00,00,9E,00,00,00,FC,00,52,
......................... 58,2D,56,38,36,33,0A,20,20,20,20,20,00,00,00,FD,00,17,79,0F, 5B,0F,00,0A,20,20,20,20,20,20,01,60
Monitor
Report information
Monitor
Report information
