AVS › AVS Forum › Video Components › Home Theater Computers › EDID Override Thread
EDID Override Thread - Page 95
post #2821 of 3084
Tried the DVI to the HDMI generic adapter. No luck. Will only send 1024x768 60Hz. Not 120Hz.
post #2822 of 3084
How do you connect? DVI -> DVI-HDMI adapter -> HDMI cable -> AVR -> HDMI cable -> projector won't work obviously.
post #2823 of 3084
OK I missed your first post. First try this:
Connect a DVI port of the graphics card directly to the projector via a generic DVI-HDMI adapter. Ignore audio part.
See if you can get 3D video this way. If not, perhaps you will need a HDMI sound card and use two HDMI cables. HD 5450 supports TrueHD and DTS-HD bitstreaming.
post #2824 of 3084
Just went out to buy a HD 5450. All the shops were closed.
Will try out your method. Hopefully this will work?
post #2825 of 3084
Got it Working.
As renethx suggested, I started all over again.
I plugged in the generic DVI-HDMI adapter/cable from the graphics card and straight to the PJ, with no other connections. I then tried the different resolutions (i.e. 1200 x 800, 60 Hz native resolution, 1024 x 768, 60Hz and finally 1024 x 768, 120Hz) all worked. Tested 3D it also worked. Incidentally this cable is 8mts long and is rated as 1.4a.
I then connected another HDMI cable from the HDMI port graphics card to the AVR for TrueHD and DTS-HD Bitstreaming, the little speaker icon at the bottom of windows task bar showed AMD audio. Checked the properties for the AMD HDMI audio and there was all the different audio formats supported. Phew.
Tested the audio and all looks goooooood.
I haven't run a full movie a yet. Plan to do so soon.
Just wanted to thank you'll for guiding me through this..
Once again Thank You .
Will advise when I watched a full 3D movie via the PC Blu-ray player.
post #2826 of 3084
As stated I decided to play a 3D movie.
Put in the disc and started powerdvd11.
That's when everything went horribly wrong.
No 3D. Unable to set the graphics card to 3D resolution (1024x768 120Hz).
Tried to set the resolution to native (1200x800 60Hz). Will not accept it. The projector tries to constantly find the 3D setting??? and then does nothing (black screen even though I can see the projector lamp is on).
It will only set to 1024x768 60 Hz. if I open any media player, the whole unit freezes and only a reset will start it up.
Any Advice?????
post #2827 of 3084
Hey guys I've been trying to dig through this article like crazy. I'm not sure if i'm quite understanding it the way i'd like to tho and I've been reading for a couple days now.
I have an LG BH7520T that's supposed to support LPCM, DTS HD MA, Dolby TrueHD all the good stuff right? Then I have it running from an ATI Radeon HD 6750 that carries 5.1
I can get it to carry DTS 3/2.1 on a Blu-ray in my Blu-ray drive which is nice. The only problem is when I load Star Trek Online its apparently not in surround, so maybe I have to install skyrim or something and see if its Dolby or DTS 5.1 because most of the time the computer reads pcm2/0.0 on my LG. I ran an EDID for a Sony TV to a 5.1 amp because WIndows would only show that my system was in Stereo which I've read a lot of other people had an issue similar but would have different results that wouldn't work for me.
The way its configured exactly is ATI Radeon HD 6750 ----> LG BH7520T HDMI OUT to Sony Bravia. I notice on Moninfo the Sony TV is detected and my LG is active real time. Should my PC even be transmitting 5.1 all the time? Mayb my Sony is interfering even tho its on the HDMI out and shouldn't really be putting out any sound as its run through my 5.1. PS3 works great and i'm pretty sure when I play blu-rays on the LG blu ray machine is the only time I can get the True HD or DTS HD MA.
post #2828 of 3084
Check that all audio formats are supported for the HDMI audio device in properties tab. If none is listed the AVR HDMI should be set to no passthrough of the TV audio.
post #2829 of 3084
In the properties tab before I used the EDID from a Sony TV + 5.1 system I found in here it used to say originally that I had Dolby Digital and DTS. None of the higher end stuff was being put out of my Radeon HD 6750. I assume my card only supports DTS or Dolby Digital. Although in that very same properties tab it would say that i only had a maximum of 2 channels supported by the card which doesn't make any sense as its supposed to be 5.1
Now with the EDID i forced the other modes but they don't really do anything. Now i can set it to 5.1 surround for Windows but it still only outputs LPCM 2/0.0 on the LG which my Computer and my PS3 are running into. The LG runs out to my Sony Bravia. I know my TV does support Dolby Digital as I've had it run through their before but it doesn't support much else. I'm worried that what I've read before in this forums is that it detects the TV at the end and that it only has 2 speakers so it might not read more than 2 channels? I feel like i'm getting closer or i'm just missing something small maybe.
I know my LG Blu Ray players supports almost any format and is also my 5.1 surround sound. Its supports DTS HD MA and Dolby True HD as well as LPCM at any level i believe. The Radeon is maybe the issue? Its running HDMI to my LG amp directly and it should be 5.1 and it definitely pushes through on the Blu Ray Movies. Maybe its not supposed to put 5.1 all the time and just with certain items? I'll try one of my other games i know is surround and see if i can get that to work but i'm doubting it at this point.
post #2830 of 3084
I did some more research. It seems my Amp wants to pass the sound to the TV possibly when its on my Computer HDMI for some reason. I can't turn this off either. It only gives me the option for digital output ---> LPCM, LPCM Multi-Channel, DTS Re-Encode, and Bitstream
post #2831 of 3084
I also just checked the spec on my HD radeon 6750 and its supports Dolby True HD and DTS MA formats as well. I'm not sure why there's such an issue here. I just edid overrided by creating an inf on moninfo for my LG and it went back to Stereo only support for Windows. For some reason in Moninfo it doesn't read all the outputs that my LG players is supposed to output such as DTS MA or Dolby TrueHD, it doesn't even say it has Dolby Digital which I know it has at least that low end format.
post #2832 of 3084
onitor
Model name............... LG-BDHT
Manufacturer............. LGE
Plug and Play ID......... LGE0000
Serial number............ n/a
Manufacture date......... 2011, ISO week 0
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1600 x 900 mm (72.3 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.635 - Ry 0.336
Green chromaticity....... Gx 0.285 - Gy 0.608
Blue chromaticity........ Bx 0.146 - By 0.061
White point (default).... Wx 0.280 - Wy 0.290
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-70kHz
Vertical scan range...... 58-62Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 0
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (4:3)
Detailed timing #4....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
DTS 6-channel, 1536k max. bit rate at 44/48 kHz
CE speaker allocation data
Channel configuration.... 5.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 3.2.0.0
Supports AI (ACP, ISRC).. No
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 150MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 030C003200001E0F
Report information
Date generated........... 8/9/2013
Software revision........ 2.70.0.989
Data source.............. Real-time 0x0041
Operating system......... 6.2.9200.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,30,E5,00,00,01,01,01,01,00,15,01,03,80,A0,5A,78,0A,83,AD,A2,56,49,9B,25,
0F,47,4A,21,08,00,81,80,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,40,84,63,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,40,84,63,00,00,1E,00,00,00,FD,00,3A,
3E,0F,46,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,47,2D,42,44,48,54,0A,20,20,20,20,20,01,8C,
02,03,28,70,49,10,04,05,03,02,07,06,20,01,2C,09,07,07,09,07,07,15,07,50,3D,06,C0,83,0F,00,00,68,
03,0C,00,32,00,00,1E,0F,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,84,63,00,00,9E,8C,0A,D0,8A,20,E0,
2D,10,10,3E,96,00,40,84,63,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,B0,84,43,00,00,18,8C,0A,
A0,14,51,F0,16,00,26,7C,43,00,B0,84,43,00,00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,31
post #2833 of 3084
The funny thing is I don't think that data is right as it should support DTS MA, Dolby True HD, and several other formats than the ones listed. Its also supposed to support LPCM Multi-Channel.
post #2834 of 3084
Sorry to post in a row like this but I keep finding new information and it doesn't let me edit the posts.
Here's what I will quote from the manual in a weird section that should be also mentioned in the audio parts of the manual as its hard to notice it. LG BH7520T manual says "The player sends audio from the HDMI inputs to both the HDMI output and to the unit's speakers" i'm guessing by that wording it doesn't allow you to change that. This may be where this issue is coming in as the computer may be passing through the signal to the TV and reading it only has 2 channels. However, moninfo does recognize 6 channels from the LG, does Windows and AMD just ignore the LD readings? Even so, i'm still surprised at how moninfo isn't showing all the options that should be available and neither is the AMD driver showing anything more than DTS or Dolby Digital when both the video card and my player both play DTS MA and Dolby trueHD according to the specs.
So my question now is, is moninfo right and my player only supports those 2 types of files in LPCM, AC3, and DTS? No dolby? Seems all really weird to me. Should I be taking the LG back or getting a Nvidia video card? I think I can take the LG back but if the ATI is the problem its 2 years old now and I can't return that, but this whole time I thought I was getting 5.1 so I don't get it. I could've sworn Skyrim was in Surround but i'm starting to think it wasn't now as I was constantly testing it and couldn't really tell I think but never thought twice about my card as it said on the box it supported all the HD quality DTS and Dolby formats.
Is my TV the issue, even though its specs Sony KDL 40EX400 state that it has 5.1 outputs (probably the optical) but it would maybe be whats being read by the computer as an output now from the amp as only a 2 channel system?
EDIT: Hey I found edit. Sorry i'm not used to the layout of this board. However I am updating to say i'm going to try the ATI beta drivers 13.8 and then i'm going to try and older driver and see if that solves anything, long shot in the dark.
post #2835 of 3084
Post the real-time EDID of your TV to add to it a full audio block.
post #2836 of 3084
I don't know if I can get real-time unless I plug it straight through to the tv.
Monitor
Model name............... SONY TV
Windows description...... Generic PnP Monitor SONY TV
Manufacturer............. Sony
Plug and Play ID......... SNYEA01
Manufacture date......... 2010, ISO week 1
Extension blocs.......... 1 (Unknown - 0x00)
DDC/CI................... n/a
Report information
Data source.............. Registry
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,01,EA,01,01,01,01,01,14,01,03,80,A0,5A,78,0A,83,AD,A2,56,49,9B,25,
3E,0F,46,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,4F,4E,59,20,54,56,0A,20,20,20,20,20,01,5F
i'm going to plug it straight in to try and get the real time numbers for you tho
post #2837 of 3084
Monitor
Channel configuration.... 2.0
Front LFE................ No
Front center............. No
Rear left/right.......... No
CEC physical address..... 2.0.0.0
Supports AI (ACP, ISRC).. Yes
Data payload............. 030C002000801E0F
Report information
Raw data
3E,0F,46,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,4F,4E,59,20,54,56,0A,20,20,20,20,20,01,5F,
02,03,22,70,49,10,04,05,03,02,07,06,20,01,26,09,07,07,15,07,50,83,01,00,00,68,03,0C,00,20,00,80,
1E,0F,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,84,63,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,
40,84,63,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,B0,84,43,00,00,18,8C,0A,A0,14,51,F0,16,00,
26,7C,43,00,B0,84,43,00,00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,F7
I had to get this by plugging my Computer directly to my TV. Now i'm plugging it back into my amp that goes out to my tv
post #2838 of 3084
Do you think I should delete my TV from the Registry possibly as I only want the LG amp to be detected?
The reason why I say this is because the LG amp is seen as the monitor by my computer (in device manager only 1 monitor is shown and its my LG blu ray player), or are they still loading both registry's like I have both hooked up?
post #2839 of 3084
Try the attached EDID override:
SONY TV - LG-BDHT.zip 1k .zip file
post #2840 of 3084
I will try it right now.
post #2841 of 3084
Its a no go. Still saying in the windows control panel "Stereo" and everything other than movies is "LPCM 2/0.0" as i'm trying to get at least 5.1 lpcm. or anything in 5.1
post #2842 of 3084
That means that it's not correctly installed. Double-check installation procedure (see my sig.).
post #2843 of 3084
OK, by looking at the specs of the lg-BH7520T this is a device that will only play HD audio from the bulit-in BD player, and the HDMI input will only accept a S/PDIF bandwidth (as per EDID specs).
So, it's indeed max 2-LPCM and 6-AC3 and 6-DTS passthrough audio over the HDMI connection. You'll only get 5.1 with applications sending a non-decoded AC3 or DTS stream.
post #2844 of 3084
That's strange because I have my PS3 running through the other HDMI in and it gets DTS 3/2.1
Its only my computer that does this. I was able to re-install and select the 5.1 surround but it doesn't play the sound out of those speakers.
Shouldn't it play or is it because the PS3 games all have Dolby or DTS on them already? That's probably why I get 5.1 sound out of the movies on my Nero Blu Ray Player on my Computer's Blu-ray Drive but not my games?
As well would that mean that, like you said, my only way is through S/PDIF but isn't that also max 2 channel LPCM? Meaning basically there's no way to get 5.1 LPCM from my current amp from my Computer? But XBOX 360, PS3 will all be fine because those games already include that stuff on the software? If so I might have to consider returning this for something that will do the job.
post #2845 of 3084
Hi, I'm looking to get an EDID override for my panasonic tc-p60st60 to be able to play 3D video games at 1080p/60hz. I have Nvidia's 3dtv play and it automatically changes to 720p/60hz when attempting to play games in 3D. I'm attaching the EDID for my tv. Any help would be appreciated!
panasonic_tc-p60st60.zip 1k .zip file
post #2846 of 3084
AFAIK it's not possible with current NVidia drivers. Search for related posts in the thread.
post #2847 of 3084
Apologies, the right place was here: http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs
Edited by SaturnusDJ - 8/18/13 at 11:39am
post #2848 of 3084
hi,
I have HTiB Samsung HtE-6730w, and a Samsung TV un55es8000f. I can't get to see DTS-HD or True Hd under windows 8. My video card is ATI 6970.
my setup: PC >> HTiB >> Samsung Tv. is the problem related to EDID?
samsung HTiB website http://www.samsung.com/us/video/home-theater/HT-E6730W/ZA-specs
Monitor
Model name............... SAMSUNG
Manufacturer............. Samsung
Plug and Play ID......... SAM094D
Serial number............ 1
Manufacture date......... 2011, ISO week 46
Screen size.............. 1210 x 680 mm (54.6 in)
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Horizontal scan range.... 15-81kHz
Vertical scan range...... 24-75Hz
Video bandwidth.......... 230MHz
Detailed timing #1....... 1366x768p at 60Hz (16:9)
Modeline............... "1366x768" 85.500 1366 1436 1579 1792 768 771 774 798 +hsync +vsync
720 x 400p at 70Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 720p at 60Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
IT underscan............. Supported
Native formats........... 1
Detailed timing #2....... 1280x720p at 60Hz (16:9)
Detailed timing #3....... 720x480p at 60Hz (16:9)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96 kHz
DTS 6-channel, 1536k max. bit rate at 32/44/48 kHz
Channel configuration.... 7.1
Rear left/right center... Yes
CEC physical address..... 2.1.0.0
HDMI video capabilities.. Yes
EDID screen size......... Rounded to nearest cm
3D structures supported.. Top-and-bottom, Side-by-side w. horizontal sub-sampling
3D formats supported..... Mandatory formats plus some primary VICs
Data payload............. 030C002100801E21D006014000372050
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
CE video capability data
CE scan behavior......... Supports overscan and underscan
IT scan behavior......... Supports overscan and underscan
PT scan behavior......... Not supported
RGB quantization range... Not supported
YCC quantization range... Not supported
Report information
Date generated........... 8/31/2013
Data source.............. Real-time 0x0021
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,4D,09,01,00,00,00,2E,15,01,03,80,79,44,78,0A,EE,91,A3,54,4C,99,26,
0F,50,54,BD,EF,80,71,4F,81,C0,81,00,81,80,95,00,A9,C0,B3,00,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,A0,5A,00,00,00,1E,66,21,56,AA,51,00,1E,30,46,8F,33,00,A0,5A,00,00,00,1E,00,00,00,FC,00,53,
41,4D,53,55,4E,47,0A,20,20,20,20,20,00,00,00,FD,00,18,4B,0F,51,17,00,0A,20,20,20,20,20,20,01,23,
02,03,35,F1,47,90,04,05,03,20,22,07,2C,09,1F,07,0F,1F,07,15,07,50,3D,07,C0,83,4F,00,00,70,03,0C,
00,21,00,80,1E,21,D0,06,01,40,00,37,20,50,E3,05,03,01,E2,00,0F,01,1D,80,18,71,1C,16,20,58,2C,25,
00,A0,5A,00,00,00,9E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,8C,0A,D0,8A,20,E0,2D,
10,10,3E,96,00,A0,5A,00,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,0E
post #2849 of 3084
It's the rule with these HT systems: the bandwidth over the HDMI input (s) is S/PDIF, so no HD audio-in. Only the built-in BD player will give you TrueHD or DTS-HD.
Edited by Tulli - 8/31/13 at 4:11pm
post #2850 of 3084
ok, but I found this http://www.samsung.com/us/support/faq/FAQ00001324/69240/HT-E6730W/ZA
can you explain this?
also, I had windows 8.1 installed, I just reinstalled windows 7 x64. Now I have this. 8 channel .
