AVS › AVS Forum › Video Components › Home Theater Computers › EDID Override Thread
EDID Override Thread - Page 98
post #2911 of 3084
Oke, since i removed the override, i did it again, rebooted after installation, checked on Device manager and i saw that the override itself worked. (still hooked the HTPC to the tv) Now i will turn off the system to hook it onto my amp and check again. If it still says it's the edid override, im gonna check xbmc or PowerDVD if the settings are correct.
Oh and im running Windows 7
post #2912 of 3084
oke, i've tried again, still says EDID override, tried every possible option in XBMC, but still no HD audio.
When i went to the settings for my audio, it still says 6 channels max. Shouldn't it be 8 if the override worked?
Edited by Sasja Jolsma - 11/8/13 at 10:10am
post #2913 of 3084
Yes, that's correct. My bad. Here's the fixed mod:
Samsung UE40ES7000+ONKYO HT-R390.zip 1k .zip file
post #2914 of 3084
Tried it again, screen turns pink/greenish but had 8 channels. Recovered previous drivers and tried it again, got 6 channels.
I'm gonna try it again, i think i did something wrong
Update: Tried it again, after i did the override i get 8 channels when the htpc is directly connected to the tv, but 6 when connected to the amp
Oh and after the override, if i connect the htpc to the amp, in device manager it says generic upnp
Edited by Sasja Jolsma - 11/8/13 at 12:16pm
post #2915 of 3084
I tried it on more time and this time it worked perfectly (accept for Powerdvd, gonna look into that)
I did do something wrong, since with the override, i only got 8 channels when directly connected to the pc and 6 when connected to the amp, so i did the override when connected to the amp (i guess thats what went wrong?)
Anyway, I can't thank you enough for your help.
I still have 1 more question: If i ever want to reinstall Windows again, i asume i have to do this override again, right?
(just checking, before i delete the file)
post #2916 of 3084
Apply the override when connected to the AVR/amp.
Yes, the override will always be required because of the bug with the AMD drivers and 6 channels EDID detection. I'ts been there for more than 2 years but AFAIK it's still not fixed by AMD.
BTW with PowerDVD you have to select a "third option" in the audio setup during playback. Haven't used PDVD for years but I guess it's the same process.
Edited by Tulli - 11/8/13 at 1:33pm
post #2917 of 3084
great, thanks again for your help
post #2918 of 3084
Hi Tulli
From what I understand, I think I have this issue. Every so often Windows 8.1 will show nothing in 'Supported Formats' - 'Encoded Formats' and the only way for the correct information to be shown is for me to reset my amp by going into 'GUI Mode' then out of it again.
Hardware
Receiver - Sony STR-DN1030
TV - Samsung UE32D5520
Nvidia 660GTX Ti
Windows 8.1
This is an EDID handshake issue right? How do I fix this, it is VERY annoying?
Thanks in advance
post #2919 of 3084
post #2920 of 3084
Sorry mate can you explain this please?
post #2921 of 3084
Your problem happens when switching on (or turning on/off) the TV or the AVR, right? (Otherwise should be a cable problem). There's either the "free fix" of blocking pin 19 on the HDMI connector (worth trying but reportedly with HDCP errors on WMC) or getting a Gefen HDMI Detective (or Dr. HDMI) to keep the HDMI connection alive regardless of switching (no EDID override fix possible). Follow the dialogue in that thread for more information or search through both EDID threads, as this problem has of course been discussed many times.
Edited by Tulli - 11/9/13 at 4:05pm
post #2922 of 3084
Hey guys, I'm at my wits end here with trying to do a EDID override on a new computer build. I have been dealing with this BS problem since 2008 with my 24 inch westinghouse. (L2410NM). I have been successfully been able to add in the code into the nvdisp.inf file to correct the washed out color/fuzzy look, but on the new gaming computer I built with Windows 8, the graphic driver install now errors out with the altered code. I have no idea what to do now.
Here is the original thread I have been using for the last 5-6 years.
https://forums.geforce.com/default/topic/396503/geforce-drivers/colors-are-washed-out-fuzzy-with-nvidia-driver/
Here is the line of code I have been putting in the commonbase_addreg sections:
HKR,, OverrideEdidFlags0, %REG_BINARY%, 5C,85,80,51,00,00,FF,FF,04,00,00,00,7E,01,00
I have a GTX780 with the 331.65 Drivers with Windows 8.1
post #2923 of 3084
I use the following procedure (see post #5). It works with Windows 8 too (and I guess with Windows 8.1):
https://forums.geforce.com/default/topic/404796/geforce-drivers/xfx-gtx-295-problems-i-have-two-problems-main-one-being-black-levels-are-wrong/#entry1005774
post #2924 of 3084
Tulli,
I have seen this thread before as well, but it isn't the same problem that I am experiencing. If you take a peak at the link I posted it gives more detail of what I'm seeing.
Also, just for the hell of it I went and did what Post #5 said to do and the installation error'd out again.
I've also noticed they changed the file of the nv_disp.inf to nv_dispi.inf. Not sure if it's just a coincidence that the regular fix no longer works when the file name changes.
Edited by Dawson14 - 11/11/13 at 7:24pm
post #2925 of 3084
Hi, is it possible get edid override with this lineup:
asus m4n78 pro mobo
yamaha htr-3065
lg 42 plasma (i cant remember model)
connections are pc-avr-tv  with hdmi
Sorry for my bad english. Thanks a lot.
Edited by sekoku - 11/12/13 at 1:38am
post #2926 of 3084
Originally Posted by Dawson14 View Post
Tulli,
Can you try an older driver on W8.1?. 327.23 works fine for me on Windows 7.
post #2927 of 3084
asus m4n78 pro mobo
yamaha htr-3065
What's the issue, exactly? Your OS and graphic adapter?
post #2928 of 3084
That was my next step. I was going to have to revert back to older drivers. But the oldest 780
Drivers on nvdias site are really not that old for the GTX780 and say BETA.
post #2929 of 3084
Windows 8.1
I use integrated graphic adapter, and it is geforce 8300
I cant see my yamaha receiver on nvidia control panel i only see lg tv. And sometimes hdmi singal lost, i think its some hdmi handshake problem?
post #2930 of 3084
No real problem with the AVR ID not showing up on NVCP as long as it works.
Handshaking issues due to switching, powering on and off the TV, cannot be fixed with an EDID override. See post #2921 above.
post #2931 of 3084
Ok, thanks. Is it normal when i look windows audio settings there are only stereo and 7.1 audio not 5.1 audio?  I have to try that 19 pin trick, is it ok?
post #2932 of 3084
Yes, 7.1 means the maximum number of channels specified in the EDID.
As for the blocking of pin 19 it has worked for some. Only problem reported that I am aware of is non-HDCP detection in Windows Media Center.
post #2933 of 3084
Thanks! Its ok i dont use wmc. What is the best method to block that 19 pin? i have to block it both side of cable?
post #2934 of 3084
Thanks to the original poster.
post #2935 of 3084
I have block it both side of hdmi cable or  pc side or avr side?
Sorry my english are bad!
post #2936 of 3084
I haven't done it myself and it's been posted in the thread, but I guess that blocking any of the two sides should work.
post #2937 of 3084
I tried this driver tonight and it still fails when trying to load the drivers after altering the code.
post #2938 of 3084
Ok, so I just tried installing the 327.23 drivers on my old rig with Windows 6 x64 PRo. I think I may have found the issue.
When you alter the inf file, Windows 7 will throw up a warning saying it cant verify the author of the file. It gives you the options to install anyway, or not to install. If you select not to it fails. If you select install anyway it takes. Windows 8.1 no longer gives you this option and just automatically cancels the install. You manually change the settings in Windows 8.1 to disable the setting. Here is the link that explains whats going on.
http://3dvision-blog.com/8483-how-to-install-edid-override-inf-monitor-drivers-in-windows-8/
post #2939 of 3084
Just went through and disabled the Driver Signature Enforcement in Windows 8.1, rebooted, tried to reinstall 327.23, and it gave me the window letting me choose two options like in Windows 7. And sure enough, it worked. SCORE!!!!!!!!! Wish I had the 5 hours of my life back though. Nvidia is seriously starting to piss me off though. I realize it's not their fault, but after 7 years of the same EDID problems with manufacturers, for the love of God just add the code. It would take them 5 mins to add all the EDID overrides. I swear some head programmer is too prideful to do it or something.
post #2940 of 3084
This has been bothering me for quite some time so I thought that I would see if I can get some extra eyes on this. My setup is...well complicated. I run a dual projection setup for 3D and I need the 7.1 HD audio available. HTPC is using AMD6790 with 13.9 drivers. The chain is
PC----Onkyo TX-NR809----1.4a multiplexer, (1)back to PC monitor, (1) feed to IN Optoma 3D-XL (for left view) and OUT to JVC RS40, (1) feed to ( IN Optoma 3D-XL for right view) and OUT to JVC RS40
The issue is that the Onkyo doesn't show that it supports 3D in the extension blocks, it's supporting the HD audio's. See below:
Onkyo TX-NR809
Monitor
Model name............... TX-NR809
Manufacturer............. Onkyo
Plug and Play ID......... ONK0B82
Serial number............ n/a
Manufacture date......... 2011, ISO week 0
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 890 x 500 mm (40.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-126kHz
Vertical scan range...... 23-240Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 720p at 120Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1400 x 1050p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Not supported
YCbCr 4:2:2.............. Not supported
Native formats........... 1
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Detailed timing #3....... 720x576p at 50Hz (4:3)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
640 x 480p at 60Hz - Default (4:3, 1:1) [Native]
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 480p at 60Hz - DVD (16:9, 16:27)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
1440 x 576p at 50Hz - DVD (16:9, 32:45)
2880 x 480p at 60Hz - Console (4:3, 2:9)
2880 x 480p at 60Hz - Console (16:9, 8:27)
2880 x 576p at 50Hz - Console (4:3, 4:15)
2880 x 576p at 50Hz - Console (16:9, 16:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 8-channel, 640k max. bit rate at 32/44/48 kHz
DTS 8-channel, 1536k max. bit rate at 44/48 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DTS-HD 8-channel, 16-bit at 44/48/88/96/176/192 kHz
DVD-A 8-channel at 48/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 11/15/2013
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0021
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,3D,CB,82,0B,00,00,00,00,00,15,01,03,80,59,32,78,0A,EE,91,A3,54,4C,99,26,
0F,50,54,21,08,00,81,FC,81,00,81,80,90,40,95,00,B3,00,A9,40,D1,C0,01,1D,80,18,71,1C,16,20,58,2C,
25,00,C4,8E,21,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E,21,00,00,9E,00,00,00,FC,00,54,
58,2D,4E,52,38,30,39,0A,20,20,20,20,00,00,00,FD,00,17,F0,0F,7E,11,00,0A,20,20,20,20,20,20,01,79,
02,03,37,C1,4E,81,02,03,11,12,04,0E,0F,1D,1E,23,24,25,26,38,09,7F,07,0F,7F,07,17,07,50,3F,06,C0,
4D,02,00,57,06,00,5F,7E,01,67,54,00,83,4F,00,00,66,03,0C,00,11,00,80,8C,0A,D0,8A,20,E0,2D,10,10,
3E,96,00,04,03,00,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,10,09,00,00,00,18,8C,0A,D0,90,20,
40,31,20,0C,40,55,00,04,03,00,00,00,18,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,59
I found a Panasonic that had the right 3D timings listed below becaus my JVC didn't even list any (frustrating):
TX-P50VT20E 3D
Monitor
Model name............... Panasonic-TV
Manufacturer............. Panasonic
Plug and Play ID......... MEIA0A4
Manufacture date......... 2010, ISO week 0
Screen size.............. Undefined or variable
DDC/CI................... n/a
Red chromaticity......... Rx 0.640 - Ry 0.345
Green chromaticity....... Gx 0.291 - Gy 0.635
Blue chromaticity........ Bx 0.163 - By 0.093
White point (default).... Wx 0.288 - Wy 0.296
Horizontal scan range.... 15-68kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 150MHz
Native/preferred timing.. 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
IT underscan............. Not supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Detailed timing #3....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
1920 x 1080p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CEC physical address..... 3.0.0.0
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Maximum TMDS clock....... 190MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. Yes
EDID screen size......... No additional info
3D structures supported.. Frame packing, Side-by-side, Top-and-bottom, Side-by-side w. horizontal sub-sampling, Side-by-side w. quincunx sub-sampling
3D formats supported..... Mandatory formats plus some primary VICs
Data payload............. 030C003000B8262FC00A8149FFFC06160800180000000000
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... Yes
AdobeYCC601 support...... Yes
AdobeRGB support......... Yes
Metadata profile flags... 0x01
Report information
Data source.............. File
Raw data
00,FF,FF,FF,FF,FF,FF,00,34,A9,A4,A0,01,01,01,01,00,14,01,03,80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,D0,72,38,2D,40,10,2C,
45,80,BA,88,21,00,00,1E,02,3A,80,18,71,38,2D,40,58,2C,45,00,BA,88,21,00,00,1E,00,00,00,FC,00,50,
61,6E,61,73,6F,6E,69,63,2D,54,56,0A,00,00,00,FD,00,17,3D,0F,44,0F,00,0A,20,20,20,20,20,20,01,D3,
02,03,36,72,50,9F,90,14,05,20,13,04,12,03,11,02,16,07,15,06,01,23,09,07,01,78,03,0C,00,30,00,B8,
26,2F,C0,0A,81,49,FF,FC,06,16,08,00,18,00,00,00,00,00,E3,05,1F,01,01,1D,80,D0,72,1C,16,20,10,2C,
25,80,BA,88,21,00,00,9E,01,1D,80,18,71,1C,16,20,58,2C,25,00,BA,88,21,00,00,9E,01,1D,00,BC,52,D0,
1E,20,B8,28,55,40,BA,88,21,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,BA,88,21,00,00,1E,00,96
Unfortunately if I combine one or the other I get the 3D support but only 2D audio or the HD audio but I can't get it to do frame packed 3D streaming because this info resides in the same extension block area. So, this is what I get:
Combined AVR with TV
Monitor
Horizontal scan range.... 26-95kHz
Vertical scan range...... 24-120Hz
Native/preferred timing.. 1280x720p at 60Hz
Modeline............... "1280x720" 74.500 1280 1344 1472 1664 720 723 728 748 -hsync +vsync
CE colorimetry data
Report information
Raw data
0F,50,54,21,08,00,81,FC,81,00,81,80,90,40,95,00,B3,00,A9,40,D1,C0,1A,1D,00,80,51,D0,1C,20,40,80,
35,00,00,00,00,00,00,1C,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,04,03,00,00,00,18,00,00,00,FC,00,54,
58,2D,4E,52,38,30,39,0A,20,20,20,20,00,00,00,FD,00,18,78,1A,5F,11,00,0A,20,20,20,20,20,20,01,06,
The above is actually what I was using with an old AMD driver 12.4 because I was able to turn off the receiver and turn it back on and it would the playback device list would list the AMD device with full 7.1 and all the HD audios (DTS-HD, Dobly True HD, etc). The only reason I updated is because I've been having audio sync issues with blu rays. I use TMT 5 with most recent, disabled auto refresh and using My Movies auto refresh. I could get sync sometimes but most of the time it wouldn't work, so I thought maybe I would use the new drivers and work through the EDID problem but I'm not sure how to combine the two traits to get what I need. I know that I may not be able to do it with these EDID's either. Sorry for the long post.
