i have a hitachi 55hds69 can someome post the proper edidoveride txt. for me
my brain is fried!! Still no sound through hdmi.Also no option to select hdmi in sound control panel.I have installed every driver i can find and nothing changes.
xps420
ati radeon hd 2400 pro
proper dvi to hdmi adapter
Monitor
Model name............... FPD TV
Manufacturer............. Hitachi
Plug and Play ID......... HTC0083
Serial number............ n/a
Manufacture date......... 2006, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.651 - Ry 0.335
Green chromaticity....... Gx 0.218 - Gy 0.717
Blue chromaticity........ Bx 0.146 - By 0.052
White point (default).... Wx 0.268 - Wy 0.283
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-50kHz
Vertical scan range...... 59-61Hz
Video bandwidth.......... 90MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
1024 x 768p at 60Hz - VESA
640 x 480p at 60Hz - VESA STD
1024 x 768p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Detailed timing #4....... 1440x480i at 60Hz (16:9)
CE video data (timings supported)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.2.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 1/28/2009
Software revision........ 2.20.0.779
Raw data................. 00,FF,FF,FF,FF,FF,FF,00,22,83,83,00,00,00,00,00,00,10,01,03, 80,10,09,78,0A,FE,5A,A6,55,37,B7,25,
......................... 0D,44,48,20,08,00,31,40,61,40,81,40,01,01,01,01,01,01,01,01, 01,01,01,1D,80,18,71,1C,16,20,58,2C,
......................... 25,00,10,09,00,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00, 04,03,00,00,00,18,00,00,00,FC,00,46,
......................... 50,44,20,54,56,0A,20,20,20,20,20,20,00,00,00,FD,00,3B,3D,0F, 32,09,00,0A,20,20,20,20,20,20,01,AE,
......................... 02,03,1B,71,47,01,02,03,04,85,06,07,23,09,07,07,83,01,00,00, 66,03,0C,00,20,00,80,01,1D,00,72,51,
......................... D0,1E,20,6E,28,55,00,10,09,00,00,00,1E,8C,0A,A0,14,51,F0,16, 00,26,7C,43,00,04,03,00,00,00,98,8C,
......................... 0A,D0,8A,20,E0,2D,10,10,3E,96,00,10,09,00,00,00,18,8C,0A,A0, 14,51,F0,16,00,26,7C,43,00,10,09,00,
......................... 00,00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,0A
