Hi, I have tried to follow the guide to make override settings but have had no luck in getting it working. I only get pcm out of my onboard hdmi but my receiver's edid data reports that it accepts dvd-a, dts-hd, sacd, etc.
This is the realtime EDID information when the receiver, tv and my computer are connected. The only problem with using the realtime data is that it makes my TV show "Mode Not Supported" at whatever resolution it defaults to on startup.
Code:
Monitor
Model name............... SAMSUNG
Manufacturer............. Samsung
Plug and Play ID......... SAM03C4
Serial number............ n/a
Manufacture date......... 2007, ISO week 49
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 160 x 90 mm (7.2 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.280 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.280 - Wy 0.290
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 26-76kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 230MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #1....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 5
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video data (timings supported)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1440 x 480p at 60Hz - DVD (16:9, 16:27)
1440 x 576p at 50Hz - DVD (16:9, 32:45)
2880 x 480p at 60Hz - Console (16:9, 8:27)
2880 x 576p at 50Hz - Console (16:9, 16:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
DTS 7-channel, 1536k max. bit rate at 32/44/48/88/96 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DVD-A 8-channel at 48/96/192 kHz
DTS-HD 8-channel, 16-bit at 48/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. Yes
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.2.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 225MHz
Data payload............. 00
Report information
Date generated........... 26/07/2009
Software revision........ 2.30.0.797
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,C4,03,00,00,00,00,31,11,01,03,80,10,09,78,0A,EE,9D,A3,54,47,99,26,
0F,47,4A,21,08,00,81,80,A9,40,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,A0,5A,00,00,00,1E,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,A0,5A,00,00,00,1E,00,00,00,FD,00,17,
3D,1A,4C,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,08,
02,03,3F,F5,4D,90,1F,04,13,05,14,03,12,20,0F,1E,24,26,E2,00,0F,E3,05,03,01,38,09,7F,07,0F,7F,07,
15,07,50,3E,1F,C0,4D,02,00,57,06,00,67,54,00,5F,54,01,83,5F,00,00,68,03,0C,00,21,00,B8,2D,00,01,
1D,80,18,71,1C,16,20,58,2C,25,00,A0,5A,00,00,00,9E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,A0,5A,00,
00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18,00,00,00,00,00,00,00,00,00,00,B2
Compare with my self-made merge which is far more boring to look at, lacking said extra sound formats, but allowing my TV to actually display something useful @ 1920x1080 instead of "Mode Not Supported".
Code:
Monitor
Windows description...... SAMSUNG (EDID Override)
Filter driver............ monitor
Extension blocs.......... 1 (Reserved - 0x00)
DDC/CI................... n/a
Horizontal scan range.... 26-68kHz
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Report information
Raw data
0F,47,4A,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,A0,5A,00,00,00,1E,00,00,00,FD,00,17,
3D,1A,44,17,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,41,4D,53,55,4E,47,0A,20,20,20,20,20,01,FB
Self-made merged inf attached.
Can some kind soul please merge my EDID information properly? I thought I could bitstream DTS/AC3 at the very least, but with my current merged inf, windows shows only "Dolby Digital" as supported.
