Moved from previous post since it does not really apply to the ASUS Rampage II topic line.
Did some initial OCing. Got the i7 920 2.67ghz up to 4.0ghz with really little effort. It was easy using the E-leet utility that comes with the eVGA x58 mobo. Just use it to set up and test OC until it fails (system will reboot with the last saved BIOS settings), then get the last safe settings and apply them in the BIOS. My settings are 192.5 QPI B Clock (~=FSB?) with a cpu multi of 21 (stock is 20) using the Intel turbo mode (192.5 x 21 = 4042.5). Voltage on CPU was bumped to 1.33 and the DIMMS (PATRIOT VIPER TRI 6G KIT DDR3-12800 instead of the OCZ 3x (2x1GB) Dual DDR3 1333 Gold XTC that I was planning to use) are set to 1.625v (to be stable with the OC). The temps on the CPU were 20-24c idle...still have not put a real stress test on it yet. But this is in my Top Deck test bench and not inside a case. No bench numbers yet since it only has a 8600GTS on the test bench. Initially had a 4870 vid card but it just runs TOO HOT (almost burns when touched) even at idle. Will move the system into my CoolerMaster HAF case later after I done some burn in tests. Pretty impress as how easy it was to OC a quad CPU (eight hyper threads) to 50% OC with very little effort on air. Using the TRUE 120 RT1366 cooler with two 120mm Noctua (1200rpm) fans in a push/pull setup for CPU cooling (couldnt use my thicker hi speed DELTAs in push/pull because of the mini tower power stage cooler on the mobo and the height of the ram heatsinks
). So much for the early fears of the i7's not being good OC'ers.
, dust buster LOUD
