JVC LINKS
Product page at Pro.JVC.com
Link To Brochure for the RS10 and RS20
RS10 Manual.PDF
RS-232C and Infrared
Remote Control Guide & HEX Codes (Thanks GaryB-UK)
RS10 Frimware update. This update improves IR sensor detection.
REVIEWS
A first Look by Jason Turk of AVS
Art @ ProjectorReviews.com
CNET UK
Cine4Home Preview of the RS20 with some info from a Pre-Production RS10
Review by Phil Hinton of AVforums
Phil Hinton Video Review
Review by John Archer of TrustedReviews
SPECS
-Enhanced 0.7-inch Full HD D-ILA devices and improved optical engine deliver the
native contrast ratio of 32,000:1 (maximum, depends on aperture setting)
for deep, true black level without a trace of gray.
-Compatibility with the latest HDMI version 1.3 (Deep Color) specifications means that this
projector can reproduce billions of colors and subtler shades of grayscale.
-Full 2.35:1 wide cinematic movie enjoyment via built in vertical stretch capability.
-Ultra quiet 19dB operation (in low lamp mode)
-Two trigger functions (screen or anamorphic lens)
-6 Point Custom Color Management.
-High-performance 2x zoom lens with motorized focus and zoom, enables flexible set-up.
-HQV Reon-VX video processor by Silicon Optix
-1000 lumen brightness with a three step fixed aperture
-Resolution 1920 x 1080 pixels
-Projection size 60 - 200 inches
-Customized gamma control on-screen
-Sleek black cabinet with black non-reflective front panel
-Wide Lens shift function (V: 80%, H: 34%)
-High-performance 2x motorized zoom lens and focus (f=21.4mm — 42.8mm, F=3.2 — 4)
-Easy-to-use self-illuminated remote control
-User Friendly Image adjustment menu
-Built in test patterns
-Outstanding Gray-scale reproduction
-Dual 1080p Capable HDMI (ver. 1.3) Digital Inputs
-HD Component Video Input
-RS-232C
-S-Video Input
-Composite Video Input
-D-sub 15-pin PC Input
-Lamp 200W UHP
-480i/p,576i/p,720p 60/50,1080i 60/50,1080 24p/60p/50p
-AC 110 - 240V,50/60 Hz
-Power consumption 280W (Stand-by mode:1W)
-Dimensions (W x H x D) 14-3/8" x 6-1/2" x 18 7/8" (365 x 166 x 478mm)
-Weight 11.0kg , 24.3 lbs
I am leaving at lunch to set her up. I will include pics.....opening her up...
