Originally Posted by
andrewturk1970
Hi, thanks for the info.
What screen brand and gain are you using ?
I'm using the "early" SMX acoustically transparent screen; 120" wide 16:9. This material was available for DIY's a few years ago. Gain is 1.1 and it works great with my RS1. Now you have to buy a full screen system to get that material, but it's top rated among AT screens, especially with their newer material. No audio EQ is required.
I really like hidden speakers, sound coming from the screen, no compromise center speaker placement (doesn't have to be mounted high or low) and the ability to use identical L,C, and R speakers. It also removes the large audio reflecting surface from the front of your theater. You can treat the wall behind the screen with sound absorption to good effect.You easily have the lumens to do this with your proposed screen size.
