AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Official JVC RS10/HD350 Owners Thread!
Official JVC RS10/HD350 Owners Thread! - Page 64
post #1891 of 2026
Originally Posted by Guinness77 View Post
William,
I am having a bad day typing. The original post should say 30 months (I am 6 months out of warranty).
Then I guess you are sort of at their mercey. That is not something that should not go as quick if at all. If others are starting to have a similar issue than mabey this is some sort of defect and should be taken into consideration for good CSR and to maintain theyre rep. I hope you have good luck in having this taken care of. If they insist in that kind of charge for this repair then mabey you would be better off looking elseware for a different brand pj . There are definately some good deals out there for the price of that repair.
post #1892 of 2026
Can anyone confirm the bulbs used in the HD350 are made by Philips?
post #1893 of 2026
I just heard that JVC will not cover the repair. I understand its their choice since it is out of warranty. I will remember that when making a new purchase this fall.
Now they want to charge me a $100 dollar fee for diagnosing the problem. They said "it clearly states a diagnostic fee will be charged on the form you sent in with the projector". After reviewing the form that I filled out and sent in on the phone with the customer service rep (I also emailed her the PDF forms I received from JVC) ,she said "oh, it is not on the form that was sent to you, but it is shown on another form we have here. There is nothing we can do, we have to charge you this fee. You can contact JVC customer service".
Now I am just trying to get the projector sent back without paying a "diagnostic fee". Again, this should have been stated on the form I filled out that was sent by JVC (knowing that I was out of warranty from the beginning).
Waiting to hear back from JVC now.
post #1894 of 2026
First get a customer service supervisor on the phone explain the situation. If not to your satisfaction I would call the corporate office and go in a different direction like sales department someone in charge there. It works believe me. I had a smaller issue with them and it was taken care of.
post #1895 of 2026
If they still balk on discounting the repair costs, maybe they can offer you a refurb HD250 at a much lower price than their original repair estimate....it would seem logical.
post #1896 of 2026
Wow! I was within 30 days of my warranty expiring on my RS-10 and had the same pink vertical line. I sent the PJ in with the warranty forms and they replaced the optical block. I am sure glad I caught the problem when I did. I would talk to a CS supervisor and see what they can do for you.
post #1897 of 2026
so I've just discovered a vertical blue band on the left side of the screen, top-to-bottom. Its about 3" wide on a 115" wide projected image. If you use the 2.5% overscan setting, it disappears.
Can it be fixed? Is it worth sending in to JVC. I ahve to check, but I might still be in the warranty period.
post #1898 of 2026
If you are still in the warranty period I would send it in its worth the shipping cost vs. the $3463.00 that it cost Guinness77. A new bulb will really make the line show up worse,it did mine--just my opinion
post #1899 of 2026
If you are in warranty I would definitely send it in. Hopefully they can turn it around quick for you. Mine is being sent back to me (I got out of paying the diagnostic fee, but it still cost me $200 to have it shipped both ways). I will limp by with the line until the new crop of projectors is out.
post #1900 of 2026
If they are going to charge $100 for a diagnostics fee, they ought to tell you more than "it needs a new optical block" since we can figure that out ourselves by seeing the blue line. I'd really like to understand what particular aspect of the "optical block" is failing.
post #1901 of 2026
That would have been nice, but they just said "the optical block is not able to be serviced". For now I will hold on to the unit, maybe in the future they will offer a repair if enough peoples units have problems.
post #1902 of 2026
Mine only has 150 hours on it.....total. Original bulb. I bought it from the local dealer. I think I'll drop it with them and see if they'll deal with it.
post #1903 of 2026
While I've been a DLP owner/fan for many years now, the advances JVC has made with LCOS tech has been impressive, impressive enough for me to watch some of these threads. But I have to admit, I've read enough posts over time with optical block issues it has me worried.
I've read that LCOS (panels or optical blocks?) have issues with heat (relative to DLP's). Supposedly it's one of the reasons it's been hard for them to increase lumens (due to the heat from the higher watt lamps). This might explain the large cases and elaborate cooling designs LCOS PJ's seem to have. I guess a good side effect of that is that they run practically silent
Maybe this is the wrong thread to bring this up, but after reading the posts on optical block failures, and especially the "Oh Well" that JVC had given to Guinness77's optical block failure, I just had to voice.
post #1904 of 2026
Early DILA's used 420 W (xenon) lamps and IIRC were quite reliable.
They were noisy though.
post #1905 of 2026
Because...??
post #1906 of 2026
Because...??
Sounds like an empirical observation. But my guess would have something to do with the "noisy" part... lots of airflow... keep in cool.
post #1907 of 2026
So I just checked on my purchase date....12/3/08! Ahhhh! Almost 3 years. How time flys. No way I'm putting +$3000 into an optical block replacement. I'll use the 2.5% overscan setting and happily wait to replace it with the RS-55 just announced. Then I'll sell it and get what I can for it.
post #1908 of 2026
By my count that's 3 generations of projectors since mine: RS-10 (mine), RS-15 (+1), RS-40(+2), RS-45(+3).
I have to think there are enough improvements since my RS-10 to pull the trigger on an upgrade! :-)
post #1909 of 2026
What did your dealer say??
Yes there have been many improvements but my RS-10 still has a wonderful/great picture and I personally am waiting until they figure out how to get rid of the glasses in 3D projectors. It might be a few years yet especially for the costs to be in the 3-5K range
post #1910 of 2026
Quick mounting/installation question...
I just purchased a HD350 (have not received it yet) and I'm planning my installation. After viewing the JVC documentation, it appears there is enough vertical lens shift that I can install the projector on a shelf right side up or ceiling mount it upside down. Is there any advantage in picture quality with one or the other? If I ceiling mount it, it will be about level with the top of the screen. If I put it on a shelf it will be a little below the top of the screen.
Both installations will put the lens about 13' from the screen. Seating is about 12' from the screen. 100" white screen with 1.1 gain.
Mike
post #1911 of 2026
Mike
With that low of a gain screen I don't think it will make much difference. The lens shift optics are surprisingly good. I guess centered is theoretically best from a lens CA perspective. But did I hear lens shift can help ANSI contrast?
post #1912 of 2026
Either setup will work perfectly. No advantage to either.
post #1913 of 2026
My dealer acknowledged its so far out of warranty I'm probably out of luck. I could ask them to push it with JVC since there are so few hours on it. One problem could come up in that my dealer dropped the JVC line since I bought it, but said they could still inquire. They now are only carrying Sony and Panny projectors.
I could contact JVC directly, but based on comments here, that would seem to be a dead-end. There is no way I'll Pay $3000+ for a new optical block.
post #1914 of 2026
Do you know, I went to the UK launch last year with an X7 (RS50) demo in a very good room that has dark walls and fully blacked out. Apart from that I was used to seeing my HD350 fully calibrated (via a VideoEQ at that time) and the X7 was just in THX mode...basically as the 3D gave me a headache and the 2D really didn't seem that much improved from my POV. Certainly not £5K improved anyway.
Since then I've got my Lumagen Mini3D and a new lamp which seems to have given my HD350 a new life. This, plus the amount of money I threw away trying different Panasonic models (AE1000, AE2000 & AE3000) before seeing the light has convinced me to wait until I see bargain basement priced used X3s or even X30s in the UK classifieds. Maybe my issues with 3D will help save me some money. Therefore I reckon I'll be 4 generations out of date before I upgrade...
post #1915 of 2026
Honestly, I don't care at all about 3D so unless there is an appreciable improvement in 2D image. I'll keep my now flawed HD350. My dealer, who is no longer a JVC dealer, told me to try contacting JVC directly and plead my case. I'll give it a try, but I'm not hoping for much.
If I switch to a different machine, based on what I know now, it could be a Sony 90 or 95.
post #1916 of 2026
Originally Posted by Kabillyhop View Post
Noah - I haven't had time to play with it. I did notice that selecting the THX mode changed the picture... can't say yet whether for better.
I just bought jbn008's RS10 and should have it on Friday. I noticed it has been a few months since you gave the RS20 firmware a whirl. Are you still using it and what are your thoughts?
post #1917 of 2026
Yes, I am still using it. For me it was an improvement as I don't have the tools or knowledge to calibrate my projector. The picture is better now, in fact it's excellent, and I don't think it's my imagination. I am not going to change it back.
Disclaimer - while I am happy with the "upgrade" I don't endorse it. I think that putting RS20 firmware on an RS10 likely entails a degree of risk. I may have been lucky.
post #1918 of 2026
Thanks for getting back to me on this. The RS10 I received today is still under warranty so I may hold off until it expires before I give it a shot. I would hate to invalidate the warranty over a firmware issue.
post #1919 of 2026
Yes I would love to try it on my 350 but same issue. do love this PJ. came from an epson9500ub A little less brightness but awesome everywhere else.
gland to see a little life left in this thread.
post #1920 of 2026
I can't imagine what kind of improvement you could see from THX setting because the projector looks pretty spectacular already. I agree, my only real complaint with the projector is the overall brightness; however, if I had to choose between the brightness of the Epson 8350 I came from to the overall picture of the JVC, I'll take the picture any day of the week.
