Making some progress here...
The thread on Media Portal forum refers to a plugin and the plugin happens to have support for Virtual CloneDrive. I have done a fresh install of Media Portal, and the plug-in isn't nessessary for enabling VCD support.
There are instructions on the main post, but basically you only need to install the DLL files and then point Media Player to the VCDmount.exe file in the Daemon Tools configuration.
1. Download this zip file which includes Core.dll and WindowPlugins.dll
enhanced_dll_rc3-svn-oct25-.zip
3. Copy Core.dll to the MediaPortal root directory (I suggest backing up original file).
4. Copy WindowPlugins.dll to Plugins\\Windows directory (again, backup original).
5. In the Media Player configuration window (General -> Daemon Tools) select the option to enabled Automount .iso/.bin files using Daemon Tools. Then click the Browse button, and point to the Virtual Clone Drive install directory and select the VCDmount.exe file. Then specify your Virtual Drive letter.
Now you should be all set for VCD mounting in Media Portal.
The only problems I have so far are getting back to Media Portal once I hit stop in TMT. TMT sits at the main splash screen. I have to click the Info button, and then select Exit to get back to Media Portal. Does anyone know how to enable the stop button to exit all the way out of Media Portal?
Credit to the original thread on Media Portal forums and -Manfred- for the plugin and .dlls.
http://forum.team-mediaportal.com/pl...l-v1-0e-37606/
