AVS › AVS Forum › Video Components › Home Theater Computers › MediaPortal Install Guide
MediaPortal Install Guide - Page 28
post #811 of 1429
Originally Posted by homesy68 View Post
hi just like to say great programme but when i go to the file with all my films in it doesnt see my m2ts films when it is scanning the moving pictures,any advice please
Did you add m2ts file extension to the list of video extensions? It doesn't appear in my config so I assume it isn't there by default.
MediaPortal Configuration, Videos, Video Extensions
post #812 of 1429
no i didnt will have to do that thanks,very new to all this but a great programme
post #813 of 1429
hi i was wondering what will this remote come under for config as it works to skip forward and back ward but dont have a pause-stop-play buttons on it
http://www.tvstick.co.uk/products/pr...tid=2&prodid=5
post #814 of 1429
Pretty sure I see a big "Play" button in the upper middle of the remote, and pause / stop buttons as well. But perhaps I'm misunderstanding your statement?
Its a standard MCE remote, will work out of the box with MediaPortal. If you want, you can configure the buttons to do anything you want in the MP Configuration section, or by using a 3rd party app like EventGhost.
post #815 of 1429
thats what i thought brian but it wont control it,im really new to this portalmedia so how would i go about setting the config up for it if it isnt any trouble to you cheers
post #816 of 1429
Im am new to this...is this software the most comprehensive? Has anyone found anyhting better yet? I'm looking to rip my blu-rays,play them, stream lossless audio through my onkyo. If this is the main program, what else should I install???SOrry, newbee here.
post #817 of 1429
In MediaPortal configuration, click the Remote section and put a checkmark in "Use Microsoft MCE remote or keyboard". That alone should be sufficient to enable base functionality of the remote. Once that's working, you can use the Mapping button to the right of that checkbox to modify what the buttons do, or use a 3rd party app like EventGhost to provide even more flexibilty and control via the remote.
post #818 of 1429
I've just installed MediaPortal 1.0.2 on my newly rebuilt HTPC with ION platform (Atom CPU, nVidia 9400 GPU). Needless to say, hardware GPU video decoding is a must.
On my previous HTPC, I was able to install PowerDVD 7 and select the Cyberlink filters from MP's configuration options.
I've installed PowerDVD 7 on the new PC with no problems (PowerDVD plays DVD's and Blu-Ray discs flawlessly), but....
Right now in MP, I can pick the Cyberlink filters for the audio, but not for the video. MP's included MPV decoder seems to work well for MPEG-2, but the only option I have for H.264 is ffdshow.... which on the Atom CPU gives exactly the results you'd expect: horrible.
I'm wondering why the Cyberlink filters aren't available on this PC when on the previous HTPC I had no problem using them in MP at all?
Suggestions?
post #819 of 1429
thanks very much will give it a try
post #820 of 1429
tried what you said brian but it still wont do anything with the play-stop-pause,so went into the mapping but how do you change the settings in there please,cheers
post #821 of 1429
Do any of the buttons work? Is the receiver light flashing when you press the buttons? What operating system are you running? If Vista, does the remote work with Vista Media Center?
Just trying to confirm you have the hardware configured correctly, because the standard buttons (like Play) are pre-configured in MediaPortal and you shouldn't have to change any of the mappings to get them to work.
post #822 of 1429
sorry for the late reply brian,im using windows 7 rtm and yes all the remote buttons work correctly in windows media also powerdvd and also TMT 3 so cant understand why mediaportal doesnt use them,im on version 1.1 mediaportal,and thankyou for your time
post #823 of 1429
wow, that is strange - only other thing I can think of is to try the fix listed in this thread - http://forum.team-mediaportal.com/bu...working-66483/
post #824 of 1429
thanks for the link brian but still no joy with it,got me puzzled this,really like using mediaportal aswell
post #825 of 1429
brian i was wondering in my device manager should i have the remote in there as ive only got keyboard and mouse,just wondering thats all
post #826 of 1429
The remote, no - but the receiver should appear under USB devices. In Vista it shows up as "eHome infrared receiver"
post #827 of 1429
I had the exact same issue using an MCE remote - worked fine everywhere (including powerdvd, tmt3, and media center), but not in MP (but I would be able to use the arrows to move around, just play/stop/rewind/back/etc would not work.
The solution was to install the IR Server Suite which is a program made by the MediaPortal team I think. It helps integrate your remote into MediaPortal and make the buttons work correctly. The ONLY thing I had to do was install the software, and during configuration choose MCE as my remote, and voila everything started working.
http://forum.team-mediaportal.com/ir...-3120-a-33512/
Hope that helps
post #828 of 1429
thanks will give it a try and report back
post #829 of 1429
thanks for all the help still wont do it,looks like i wil have to find another programme to run my films,shame as i really like this
post #830 of 1429
Download and use EventGhost. There is a Media Portal plugin for it. Then you just map the remote presses to functions in Media Portal. I had to use this to get the MCE remote to work in XP (once I installed some drivers) and it worked great.
post #831 of 1429
Originally Posted by pchannan View Post
Question for mediaportal users
I'm looking to build a server and use media portal as my front end. But I will be moving to a custom built home in 2-3 years which will likely have a crestron HA solution.
I would hate to spend $$$ on all of the server hardware (at least 15 TB) for it to go to waste when I move. Has anyone heard of mediaportal or similar software being integrated into a professional HA system? Or even just a custom built server being integrated?
I have a lot of Blu-ray iso's which I wouldn't want to lose access to.
Pete
Pete -- not sure what integration MediaPortal will have with Crestron or other high-end HA solutions.
I integrate Control4 in a lot of my custom homes, and one of my clients is using XMBC which works well with Control4. I am going to visit him in about a week or so, and will let you know how well XBMC is working in his place.
Control4 is also coming out with their own media player (I believe $399 retail) in another month or so, and this device will be able to build your library from different media storage points (Sony bluray jukebox, NAS, etc.) and show cover art on the touchscreens and TV interfaces.
I'm sure Crestron will have something similar shortly.
In the meantime, I'm enjoying MediaPortal on my HTPC and it's connected to both my dedicated home theater and my family room plasma/surround system. The interface and library are amazing!!!
post #832 of 1429
** Doing this on Windows 7 - DTS thru SPDIF not working **
H264 / MKV files, dont have pass any audio thru SPDIF to my receiver (or HDMI - dont care though). I am seeing Dolby Digital 5.1 being passed thru fine to my receiver. I have not seen any DTS - played a lot of files. Either they play stereo or no audio.
Setup mediaportal according to instructions here.
Windows 7 professional RTM.
Yamaha HTR-6050 receiver.
GA-MA785GM-US2H MB
Screenshots of my configs are below. Pls help. The MP "Video Player" config shows ffdshow as the audio decoder - I had ac3filter previously, same issue.
post #833 of 1429
GA-MA785GM-US2H MB
Couple of things:
- first check your Yamaha when it's on that input for auto mode. Not sure how it's done on Yamaha, but my Denons have an Input Mode button that changes from PCM to DTS to AUTO etc. You won't get the right audio if it's stuck on PCM or analog.
- are you able to get DD or DTS if you use another player (other than MP) on your HTPC? If not, the problem may not be related to the MP configuration but more with W7 drivers. Sorry not familiar with W7 to help further. Still running XP Pro on my box.
Good luck!
post #834 of 1429
I get DD through MP itself. The situation is the same if I use Windows Media Player Classic. I am wary of installing another player (like VLC) lest it mess with my codecs and its settings.
And yeah, have my Yamaha mode set to Strainght - which will auto decode. On this mode, my PS3 is able to send DTS / DD fine. So its not my yamaha for sure. I really want to be on Win 7 - really like it. like you said, it definitely has to do with Windows Media Foundation I believe. I used GraphStudio on one of the h264 files and it did not show any audio decoder!?!
I am contemplating some options:
* Another XP partition and try setting up MP allover in XP,
* try TMT or some other media center software which will be able to solve the issues I have on Windows 7.
post #835 of 1429
Try installing XBMC -- it's fairly harmless with MP, and is probably the easiest way to test DTS output on W7.
I have both XBMC and MP on my HTPC, running mostly XBMC until I was able to resolve an interlacing issue and get subtitles to work on MP earlier this week. I'm using the new beta version of MP, and absolutely love it!
post #836 of 1429
GA-MA785GM-US2H MB
I wasn't able to get 5.1 at all unless I set the output format to 5.1 in the first box. But you said you are getting 5.1 DD. Maybe that still has something to do with DTS not working.
post #837 of 1429
brianley im going to stick with it as it looks nice and if i need to pause it or stop it i use the mouse on the remote to go to the top and use them functions,cheers for the help
post #838 of 1429
hi i downloaded Xfactor Music MOD for StreamedMP and there is a few files in there were do i put them for the cover arts to show up in media portal just like the films thanks
post #839 of 1429
Hi
I'm just starting to use mediaportal and i just love it, i was looking for something to have my movies and series organized and easily accessible and this is it.
I have almost everything right the way i want i just need a little help with the remote, is there a way to make the remote call mediaportal automatic, and without the asistence of any other program (i know how to do it with HIP).
I have been looking in the mapping option of mediaportal but haven't been able to find it, is there any way to modify the default commands of the MCE remote, ex. change the home button to call mediaportal.
PD: System Xp SP3.
post #840 of 1429
Answer to my own question:
http://www.team-mediaportal.com/comp...ileinfo/id,77/
Hope this help someone else.
