I bought a second projector Planar PD7130 and am making a small HT room for the wife and I. The room is real small 11'-5 1/2" wide, 13'-4" deep with 8' ceiling. The room used to be an exercise room right off of our master bedroom. The floor has the black foam rubber floor tile. I painted the walls and ceiling flat black. I installed black sound panels and bass traps across the front and gray sound panels and bass traps on all the other walls.
I got a good deal on some RBH WM30's and made brackets so that I could mount them in front of the panels and traps. The sub is an old NHT 10" ported that I already had and I am using an A35 HD DVD player for DVD's. The screen is a 106" fixed frame. I was surprised at how good the on-wall RBH speakers sound when mounted in front of the panels. I took a couple of pictures. One is of the front right corner and the other is of the screen. Please excuse the spots. They are from the camera. My wife could not find where she stuck our camera and I used my daughter's underwater camera.
http://i243.photobucket.com/albums/f...m/P1010335.jpg
The Planar produces a very nice image using DVD or HD DVD. For BD I use my other system.
Added:
I am now using three small sealed subs (NHT 116 drivers) and a pro crossover to convert the three front speakers to a 3-way design. This allows me to cross to the on-wall speakers at 100Hz. I run the front three channels full range + LFE. I use the small sealed subs have an F3 of 31Hz and I run them up to 150Hz. I have also added a 6.3CF ported sub (Shiva-X) in one back corner and a 2.0CF sealed sub (2-10" drivers) in the other back corner. Now this room sounds better and has more impact than my downstairs room that uses RBH Signature speakers all around.
Added:
[/IMG] I do have grills on the subs, but you can see the Aluminum drivers in the picture because of the flash. To see more pictures, click on the link labeled "Upstairs Dedicated Room"
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
