Hi All,
It's been a long time since I posted but my home theater is finally almost finished.
I had been using a HTPC with TheaterTek with my Marquee 8500 anamorphic squeezed so I could do CIH. I just bought a Sony Blu Ray disc player. I don't know if/how I can use it and still do CIH.
If I run the standalone blu ray player directly to the Marquee using a HDFury2 or the Marquee VIM-FULLHD HDMI 1.3 Input Card offered at Curt's site is there a way to have CIH?
Or if I run the standalone blu ray player to the HTPC will I be able to do CIH?
Any other options?
I still plan to use the HTPC for TheaterTek purposes.
THANKS!!!!
Any other options?
THANKS!!!!
