Sony STR-DG2100
7.1 A/V Receiver was engineered to be the entertainment Hub for your HD experience. This receiver provides an "Audio for Video" solution, which integrates the latest technologies to optimize Sound as well as picture quality. The STR-DG2100 utilizes Faroudja DCDi Cinema Technology, which up scales non-HD sources to 1080p. In addition to video upscaling, this chipset corrects image jaggedness and reduces Block noise resulting in beautiful, smooth High Definition images. The STR-DG2100 utilizes high-grade components that provide effective heat dissipation, large amounts of power while maintaining precise sound quality. Sony's Xross Media Barâ„¢ inspired GUI allows a User to utilize an icon driven menu system, which provides easy access to the receiver's most complicated functions. The STR-DG2100 7.1 A/V receiver will accept 1080/60p and 24p HD video formats, x.v.color (xvYCC) and Deep Color while providing 3 HDMI connections. Sony's Optional Digital Media Port makes this model iPod Ready and features BRAVIA Theatre Sync technology for One-Touch Play.
- Xross Media Barâ„¢ inspired graphic user interface
- Faroudja DCDi Cinema Up Scaling Technology
- BRAVIA Theatre Sync technology
- 100-Watts x 7 Power amplifier (8 ohms, 20Hz - 20kHz, 0.09% THD)
- Accepts x.v.Color (xvYCC) and Deep Color
- Accepts 1080/60p and 24p video signal via HDMI
- Accepts 8ch linear PCM, Dolby Digital +, Dolby TrueHD and DTS HD via HDMI
- HDMI Active Intelligence (3 inputs/1 output)
- Digital Cinema Auto Calibration with Stereo microphone
- Sirius and XM Connect-and-Play Ready with Neural 5.1 Surround
- Audio Impedance: 8-Ohms
- Channel Power Rating: 100Watts x 7 Amp Power (8 ohms, 20Hz-20Khz, 0.09% THD)
- Sound Fields: Cinema - 4, Music - 7, Auto Format Decoding - 14, 2 Channels - 1, and Headphone - 4
- Tuner Type: Auto Tuning, Direct Tuning, Station Name, Presets 30 XM, FM and AM
- Dimensions: 17" x 7" x 17" (430mm x171.5mm x 430mm)
- Weight: 34 pounds 3 ounces (15kg)
Sony STR-DA2400ES:
While HDTV and standard DVD is set for 5.1 Channel Surround sound, Blu-Ray has been engineered to deliver up to 7.1 channels. The Sony STR-DA2400ES has been developed to deliver those extra channels of sound at an elevated standard to enhance your Home-theater experience at the highest level. Engineered for high-end home theaters, the STR-DA2400ES elevated standard (ES) 7.1-channel Receiver features sophisticated A/V technology that reproduces the latest Audio formats from Dolby Labs - Dolby Digital + along with Dolby TrueHD and DTS (dts HD/DTS High Resolution Audio). Expand your listening options via the Digital Media Port Input and enjoy Music on your MP3 player, PC or XM and Sirius Satellite Radio. You'll also see the difference with Faroudja DCDi Cinema technology, which upscales all your Video sources to 1080p when connected through HDMI to a compatible HDTV. Additional features include a 100-watt Power amplifier (8 ohms, 20 Hz - 20 kHz, 0.09 percent THD) per channel, BRAVIA Theater Sync, an easy-to-use graphical Interface and four HDMI inputs that are compatible with 1080 60p/24p, Deep Color and x.v.color video signals.
- Channel Power Rating: 7.1 Channel Power rating; 100W X 7 Amp Power (8ohms, 20Hz-20Khz, THD0.09%) 8 Ohms
- Sound Fields: Cinema - 4; Music, 2 Channels - 1; Headphone - 4
- Tuner Type: Auto Tuning, Direct Tuning, Station Name 30/30/30/30 (Sirius/AM/FM/AM)
- AM/FM Memory Presets: 30 FM - 30 AM
- XM Connect and Play Compatible: Neural 5.1 Surround Sound Decoding; XM Memory Presets: 30 (XM and/or Sirius require separate subscriptions and antennas for reception)
- Connectivity: Coaxial Audio Digital Output(s): 2 (Rear)
- Component Video (Y/Pb/Pr) Input(s): 3 (Rear)
- Component Video (Y/Pb/Pr) Output(s): 1 (Rear)
- Composite Video Input(s): 5 (1 Front/4 Rear)
- Composite Video Output(s): 1 Rear Monitor
- DIGITAL MEDIA PORT
- HD Component Video Input(s): 3 (Rear)
- HD Component Video Output(s): 1 (Rear)
- HDMI Connection Input(s): 4 (Rear); HDMI Connection Output(s): 1 (Rear Repeater); Headphone Output(s): 1 (Front-Gold)
- Multi-Channel Input(s): 1 (Rear, 7.1 Channels)
- Optical Audio Input(s): 4 (1 Front/3Rear)
- Phono Input(s): 1 (Rear)
- Unit Dimensions (Approx.): 17 x 6 1/4 x 16 15 3/8"; Weight (Approx.): 26 lbs 15 oz (12.2 Kg)
Sony STR-DG1200
Add dynamic stereo sound and superior digital entertainment options to your home theater with the STR-DG1200 7.1-channel A/V receiver. Using Xross Media Bar™ inspired GUI and Faroudja DCDi Cinema® technology, this receiver also upscales all standard definition video sources to 1080p. It even decodes the latest audio formats from dts® and Dolby® Labs. Boasting plenty of connectivity options, there are also four HDMI™ inputs, a Digital Media Port input for use with MP3 players, and XM® and Sirius Satellite Radio® inputs. Additionally, the STR-DG1200 features Digital Cinema Auto Calibration which simplifies speaker set up in 30 seconds with the push of a single button.
Optimized for Blu-ray Discâ„¢ and Other HD Sources3
The STR-DG1200 is engineered to be the ideal Blu-ray Discâ„¢ compatible A/V receiver, and works with the Sony family of Blu-ray Disc players (sold separately). Superior video switching and audio performance ensure easy compatibility with today's demanding HD sources. The STR-DG1200 features 4 High Definition Multimedia Interface (HDMIâ„¢) inputs which are capable of accepting resolutions up to 1080p2, offering the exceptional video quality that Blu-ray Disc format can deliver.
Decodes Latest Audio Formats
Supports Linear PCM, DD+, Dolby® TrueHD, dts®-HD Master formats which allow you a more precise audio experience.
Up to 8 channels of Linear PCM audio
Compatible with Blu-ray Discâ„¢ format linear PCM (uncompressed) output, producing up to eight channels of high quality audio reproduction.
The receiver can detect and receive the best possible video and audio signals from all connected devices-making connection and performance as simple as plugging in a single wire. Sony HDMI Active Intelligence produces both audio and video through one HDMI cable (sold separately).
Faroudja® DCDi Cinema™ Chipset for Up Scaling to 1080p
The IC processor developed by Faroudja and first used by Sony upscales video signals (less than 1080p) to 1080p via HDMI2. This chipset reduces image jaggedness and block noise, while reproducing colors that are closer to the original. The end result is a beautiful and smooth high definition image.
xross Media Bar® Inspired Graphic User Interface
An on-screen menu that simplifies the most complex operations of an A/V receiver for home theater applications. This advanced menu system incorporates icons, an easy to follow tree system and a blending technique so users know exactly where they are among the various settings while still watching their main video source (up to 1080i). The menu includes access to DIGITAL MEDIA PORT accessories (sold separately), which lets you assign HDMI inputs and provides independent A/V sync control for each input. It's simple. Just pick up the remote and a whole new experience will be revealed.
An ideal listening experience is only a button away. Simply place the included microphone in your listening position, push a single button and speaker position, distance and delays are automatically calibrated. Sony Digital Signal Processing uses feedback between the microphone and receiver to optimize sound settings.
Sirius and XM Connect-and-Playâ„¢ Ready6
A world of digital radio at your fingertips. Connect the optional antenna for either Sirius(R) and/or XM(R) subscription service and enjoy the variety and quality of digital radio with the superior sound quality of an A/V receiver.
Portable Audio Enhancer
The 7.1 A/V Receivers are ideal for today's portable audio devices. A powerful Digital Signal Processor expands the quality of sound from any connected device. Simplified front-side audio and video connections make it easy to play content from your portable audio device through the receiver.
BRAVIA® Sync for Theatre4
The receiver can transmit control functions, as well as the audio and video signals, to select BRAVIA® televisions2.
Product Specifications
General
Other
A/V SYNC (Lip Sync) : Yes(Variable)
Weights and Measurements
Dimensions (Approx.) : 17" x 6 1/4" x 15 3/8" (430mm x 157.5mm x 388mm)
Weight (Approx.) : 26 lb 15oz (12.2kg)
Speaker
Center Speaker Terminal : Yes
Speaker Terminal Type : Screw Binding Posts
Surround Back Speakers : Screw Binding Posts
Surround Speaker Terminal : Yes
Convenience
AM/FM Memory Presets : 30 FM - 30 AM
Preset Memory : 30 Sirius® Presets
Timer Clock : Yes (Sleep)
XM® Connect and Play™ Compatible : Yes (Neural 5.1 Surround Sound Decoding)
XM® Memory Presets : 30
Audio Features
Amplification Relocation : Yes
Digital Cinema Soundâ„¢ Technology : Yes
Dolby® Digital Decoding : Yes
Dolby® Digital EX Decoding : Yes
Dolby® Digital plus Decoding : Yes
Dolby® Pro Logic® Decoding : Yes
Dolby® Pro Logic® II Decoding : Yes
Dolby® Pro Logic® IIX Decoding : Yes
Dolby® TrueHD Decoding : Yes
dts® 96/24 Decoding : Yes
dts® Decoding : Yes
dts® NEO:6 Decoding : Yes
dts®-ES Decoding : Yes
Dolby® Digital Dual Mono : Yes
THX Surround : Yes(225,227 only)
Hardware
Remote Control : Yes (Advanced Learning/Pre Programed)
Power
Power Consumption (in Operation) : 350W
Power Consumption (in Standby) : 1W
Power Requirements : AC120V, 60 Hz
Convenience Features
BRAVIA® Sync™ : Yes
A/B Speaker Switch : Yes (A / B / A+B)
Digital Cinema Auto Calibration : Yes (Mic-Stereo)
HDMIâ„¢ Technology : Intelligent A/V Selector
On-Screen Display : Yes
Video Features
Up Scaling : Yes (HDMI Up Scaling up to 1080p)
x.v.Colorâ„¢ Technology : Yes
Time : 300msec
Inputs and Outputs
Analog Audio Input(s) (Total) : 4 (Rear)
Analog Audio Output(s) : 1 (Rear)
Antenna Terminal (AM Loop) : 1 (Rear)
Antenna Terminal (FM 75 Ohm) : 1 (Rear)
Coaxial Audio Digital Input(s) : 3 (Rear)
Component Video (Y/Pb/Pr ) Input(s) : 3 (Rear)
Component Video (Y/Pb/Pr) Output(s) : 1 (Rear)
Composite Video Input(s) : 1 (Rear)
Composite Video Output(s) : 3 (Rear-1 Monitor Output, 2 Video Outputs)
DIGITAL MEDIA PORT : Yes
HD Component Video Input(s) : 3 (Rear)
HD Component Video Output(s) : 1 (Rear)
HDMIâ„¢ Connection Input(s) : 4 (Rear)
HDMIâ„¢ Connection Output(s) : 1 (Rear)
Headphone Output(s) : 1 (Front- Gold)
Multi-Channel Input(s) : 1 (Rear, 7.1 Channel)
Optical Audio Input(s) : 5 (1 Front/4 Rear)
Optical Audio Output(s) : 2 (Rear)
Phono Input(s) : 1 (Rear)
RCA Audio Input(s) : 5 (Rear)
RCA Audio Output(s) : 2 (Rear)
Subwoofer Output(s) : 1 (Rear)
Audio
Channel Power Rating : 7.1 Channel Power Rating: 110W x 7 Amp Power (8 ohms, 1Khz, THD 0.7%)
Frequency Range : 192kHz
Impedance : 8 Ohms
Sound Fields : Cinema - 4; Music - 7; Auto Format Decoding - 14; 2 Channel - 1; Headphone - 4
Tuner Type : Auto Tuning, Direct Tuning, Station Name, Presets 30/30/30 (XM/FM/AM)
Accessories Supplied
RM-AAL019 Learning Remote Control
