AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › How to Turn off PS3
How to Turn off PS3
post #1 of 4
I've PS3 and Sony Bluray Remote.
- I couldn't locate any button in remote to turn off the PS3.
- Even if I step out of my couch and manually press the power/standby button in PS3, it doesn't turn off. I have to turn off the power switch located in the rear.
Am I missing anything?
TIA.
post #2 of 4
The remote dose not have a power button, You have to keep your finger on the sensor button for about 4 second to turn off the player.
Hope this help
post #3 of 4
Keep the the "PS" button pressed on the blu-ray remote or the sixaxis controller for a second. You will then get the option on-screen to either turn off the system or the controller. Select the former and after 2-3 seconds the PS3 will shut down itself. You can then turn it off from the rear button once the light goes red from green. I hope this clears it.
post #4 of 4
Please post all questions on this player in our official PS3 sticky thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1019115
This thread is locked
