Hey,
A number of "us" have had problems with the Guid Plus+ System - ATI (that came bundled for many years with ATI All-In-wonder card, TV Wonder, HDTV wonder cards etc. In the PAST periodic problems with Guid Plus were not uncommon. But unlike previously when an un-install / re-install or repair setup would have fixed things...there appears to be something wrong with the listing server. at http://www.gemstarguide.com/gdndl/gdnget.asp
This is the starting point of the process. Although you can modify the registry to point it to the current update page: http://144.198.100.134/gtidl/gdnget2.asp
without it first calling home the setup simply goes through the motions. Even when copying over the same registry settings from an exact same verision of a working Guide Plus, it makes no difference (*unless the Guide Plus had previously been activated, and simply needed a newer update page). It will download the guide but is unable to properly list them until it makes contact. I have two additional computers that have Guide Plus+ System for ATI working just as well as it ever did. They update and get the current listings. one is running the exact same version as the clean install system and the reinstall system that won't work Version 1.0.0.50. Also an additional working version 1.0.0.45
You can read more over here: http://www.rage3d.com/board/showthre...post1335765887
But even installing the Guide Plus on a "completely clean system" Guide Plus (unlike in the past) is unable to operate.
It's unknown as to whether this is just a temporary listing server problem or issue, as they have problems from time to time or something more permanent. My current hope is that the ATI - problem reports and phone calls to Macrovision 1-800-386-7380 I an others have made will get someone to look at get the server back up.
I am posting this here so that it might inform someone else who is having similar issues with Guide Plus+ system for ATi on there HTPC system as to why it is no longer working and to save them a lot of un-installing/re-installing time. Further if anyone else has seen any AMD/ATI press releases or Macrovision information pertaining specifically to ATI users, please post them here. or in the 3d rage thread. THANK YOU.
EDIT UPDATE:
Solved the problem over on rage 3d.com Site URL I listed just above.... Even though the listing server is down...possibly permanently, at this point even a clean installation or re-installtion can get Guide Plus installed and running or back up and running with all the current analog listings.
EDIT UPDATE:
I suppose the likely delay of the DTV transition may also delay the release/deployment of the OTAis solution.
