Everything is in a separate folder with the exception of two concert DVDs by the same band. They are in separate folders IN the main folder named for the band.
I get this error when I try to click on something and play it back.
Originally Posted by jrwalte
It's possible your windows account doesn't have the permission it needs for the programdata folder. Did you setup your user account as administrator or user? Go to Windows Explorer, right click on programdata and select properties. Select Security tab and then advanced. Select Effective Permissions tab and then the 'select' button under Group or user name. Type in your user name and hit ok. What is the effective permissions listed? It should be full control.
My account is listed in the administrator's group. I just checked it's permissions and reset it to "full control" for my account just in case.
