Originally Posted by FrankiiieD
should i not have a folder called "season 1" between the folder TVShows and the files? or perhaps it should be season.1 instead? just odd that boxee picked it up when i renamed it according to media browser's guide but mb didn't. though even in boxee only the season artwork loaded, there was nothing for each file.
Originally Posted by dbone1026
Your tv show naming convention should work. You can also use a program like tvrename which will rename your tv shows to a standard convention (I like to use ShowName - S##E## - EpisodeName). Also try using a 3rd party metadata program such as metabrowser, YAMMM, or MCM instead of relying in the internal Media Browser scraper
Of all the metadata scrapers, I've had the best luck with MediaScout for TV series, with one caveat... I much prefer the older v0.9 to the current v3.0 that got bloated (in the "other downloads" section). BTW, it can simultaneously look up your TV meta data AND rename your files. I like the "Series - S##E## - Episode" format too. My folder structure is like this:
..\\[Series Name]\\Season #\\[Series Name] - S##E## - [Episode]
-for example-
..\\Lost\\Season 4\\Lost - S04E05 - The Constant.mkv
This folder structure works with all 3rd party metadata scrapers and with the built in Media Browser scraper too.
