A reason why I keep my movies (including BluRay) in ISO is that you can rewind, f.forward, and everything else like a regular disc during playback without any issues using TotalMedia 3.
I actually use an older program called TV Scout, don't know if it is even around any more.
How would I go about doing this? I was thinking that some kind of hack-job where I take the info from the one theme and paste it into the corresponding place on the other theme might work, but without looking at the code itself I don't know if its possible.
Has anyone been able to successfully get TMT5 to work with media browser and blu-ray folders?
I've applied the unofficial hotfix which allows the movie to play, but it's not fullscreen. Plus, my remote doesn't work... or at least the back button doesn't take me to WMC. I'm having problems. Anyone get it right or do we just have to wait for Arcsoft to fix it? |
So i tried out media center master and it worked ok. mostly my errors. I also tried My movies. It worked about the same. Just have to play with it.
Real thing for me is the covers. i seemed to only be able to find normal dvd covers offered. I like to have the bluray covers for my bluray rips and the normal dvd covers for th edvd rips. Am i missing an option in either program to fetch bluray covers? |
