I just set up media browser yesterday (thanks Assassin your guides are amazing) using the pearl theme, looks amazing. One minor issue I found is that using a MCE remote (Rosewill RHRC-11001 for now) when you select a category (i.e. tv shows, movies, hd movies ect) and then choose a tv series for example (cover flow is the format option), the
right navigation button on the remote will not work when trying to select a series other than seasoin 1
. I did notice that if you use the channel down(page down) button it jumps you to the end of the series list and then you can use the left arrow key to navigate, I just found it odd that the right would not work.
This is the only place it will not work, it works perfectly in the main selection menu and to choose the series you want to watch, and then after choosing a series it resumes working to choose the episode you want.
Any suggestions on how to fix this?
