Originally Posted by Shooty*
Thanks Mike.
I may not have explained myself clearly.
I have folder.jpg in place. That works on the main screen where all the movies are listed. Once I select a movie, which is in VOB files in VIDEO_TS, on that movies screen, I get nothing EXCEPT the blue "film reel" icon showing my VIDEO_TS folder, and if I click on that, I go straight into the movie.
I am using salami, which generates a mymovies.xml in each folder. I've got no problems with getting cover art, that was one of the first things I sorted myself.
There is DEFINITELY stuff in the XML file: i've opened it in notepad and checked. Perhaps it's a question of the xml file being unreadable?
It might help if I post a screen grab of mediabrowser not displaying stuff, and the content of one of the xmls, I guess. Or I could try meta browser.
Just to clarify, mike, you mention an MKV file, and I have NO problem with my MKVs or AVIs AT ALL, only straight VOB rips into VIDEO_TS folders.
Thanks Mike.
Did you try clearing your cache?
