Hi guys:
I have been reading this forum for some time and have learned a ton of information. I recently purchased a Highpower screen (mostly due to what I have read here) and absolutely love it. However, my dog licked the bottom of the screen last night leaving a small but seemingly permanent "wet mark".
According to Da Lite's cleaning instructions, the spot can be cleaned with water but says that it is very difficult to eliminate streaking. Anyone have any ideas how (or whether) I can remove the spot? Thanks for your help.
Go view it, and good luck with Spot.
that gets put on an accent table about 9' from a Projection King HP 2.8 4:3 portable that is mostly only opened to the 16:9 ratio. However, I have made a few modification to the screen that allows me to open to any ratio if I feel like it.
