UPDATED: NEW PICS AND EQUIPMENT.
For 2 channel listening:
Sonus Faber Cremona Auditor M (replaced Monitor Audio Gold Reference 20, also shown in pics below)
Odyssey Candela tube (12AU7) preamp with HT bypass
Pass Labs x350.5 2 channel power amplifier 350wpc, first 30 watts of pure class A power
Bryston BDA-1 DAC
dbx223XL active crossover
2 each JL Audio F112 Fathom subwoofers
Pioneer PL-530 turntable
John Kenny Modified M2Tech HiFace MK3 USB to SPDIF converter, BNC version
Streaming FLAC files from my pc using Foobar2000
Jensen IsoMax isolation transformer
Shunyata Venom Power Cord for the Pass amp
Custom made speaker cables, XLR and RCA by John Wood
Oyaide DB-510 BNC from the USB transport to the DAC
Just added: HP TouchPad 10" tablet, running the SplashTop Remote app to control the computer - eliminated keyboard and mouse!
HT 7.1 setup: All of the above plus:
Pioneer KURO Elite 9G Pro 151-FD 60" plasma
Onkyo Tx Sr 805 receiver
Polk Surrounds OWM5, Polk Surround backs OWM3, Polk center (upgrading to Sonus Faber sometime in the near future (will this addiction ever end??))
Pioneer 51FD bluray player
XBOX 360 slim in black color
Harmony 880 remote, monster RCA and monoprice HDMI, optical and digital coax cables
The room is soundproofed:
- 2 layers of 5/8" drywall with Green Glue in between, including the ceiling
- joists covered with rubber strips to prevent floorboard squeaking and sound travel
- all electrical plugs and switches, holes for in-wall cable runs have been sealed
- dedicated heating/AC unit with extra large registers and air return to minimize in room noise
Acoustic Treatments:
OC 705 bass traps: 4 pieces
OC 703 4 x 2 panels: 14 pieces
OC 703 2x 2 panels: 4 pieces
Poly diffusers: 14 pieces
All hand made by yours truly...
Other:
Panamax 5400 power conditioner/voltage regulator
Cowon D2 PMP, 8GB + 16GB expandable SDHC card
Lutron remote control dimmer
CLICK ON THE PICS TO ENLARGE
Edited by ddgtr - 10/26/12 at 1:04am
Love your walls and trim moulding, and the floors are gorgeous. The drapes in the front and back, as well as the artwork on the walls, are all great touches. I like your TV and equipment stands too - seems you are a bit maxxed out on space already, though? That silver amplifier (presumably the Pass Labs) is crazy! Too bad it's not black.
Wow you aint kidding! (joking of course
Although a fine center channel, but as far as tonal compatibility is concerned, is the Polk a good match with the Monitor GR20's? Do they have similar tweeters? I own a CS400i which is mated to a pair of RTi70 towers, FXi3 surrounds and a Velodyne CHT-12 sub. That setup is my family room. And I often wonder if the Polk speaker would be more effective with my main system compared to my Klipsch speaker package.
) In other words, how do you get the GR20's to become part of the multi-channel configuration?
