AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › No center channel with new Panny 55
post #1 of 7
Have it connected analog to an Onkyo HT-R530 and get everything but center on a brand new Panny BDP55. Doublechecked everything and simply ran 6 coax from dvd to receiver surround inputs. Sound is great on DVD stereo setting but no center channel. I do get center channel if I switch to MULTI CHANNEL setting on receiver versus DVD. Help. Is my Blue Ray broken or is it something esle.
post #2 of 7
With my Onkyo 505, if you are trying to use analogs, you should be using the multichannel input. The DVD input sounds like it's just giving you stereo. If you haven't run a digital coax/optical cable from the 55 I am surprised you're hearing anything on the DVD input at all.
Is there no center channel sound at all? Like no dialogue? Or can you hear dialogue but it's not coming out the center?
post #3 of 7
On multichannel I get center with no rears (weird) but on DVD setting I only get some from the front left and right. Thing is DVD sounds way better than multichannel. Ugh?!?
post #4 of 7
check your your RCA cable
post #5 of 7
RCA Cables fine. Given up on using DVD input on receiver and had decent surround on all 5 speakers on mult ch setting. Now only have fronts and center. Have lost the rears? Any suggestions? I will start scouring the 1000's of lines in the owners thread too.
post #6 of 7
Try asking for help in the Master thread.
http://www.avsforum.com/avs-vb/showt...75161&page=188
post #7 of 7
In the future, please use the master thread for your player when asking questions or needing advice. Thanks
This thread is locked
