AVS › AVS Forum › HDTV › HDTV Recorders › Moxi HD DVR
Moxi HD DVR - Page 51
post #1501 of 5911
Well, it seems as if the latest software update addressed the pausing video with external hard drives on recorded material playback. Once again, I am a happy camper
-Evangelo2
Now a personal request for MoxiGuy... Please allow for 5.1 AAC decoding in mp4 video files streamed from a windows 7 pc Or at least, allow 2 channel sound to be passed out over TosLink when I am using Dolby Digital output. This would make everything perfect to me
post #1502 of 5911
I purchased a 3-tuner DVR and a 2-tuner DVR, along with two Mates, to run on a TWC system in NYC. My initial plan was to run both Mates with the 3-tuner DVR and the second DVR was added about a week later. I have found it impossible to run the two Mates from the 3-tuner DVR, despite company claims that it should work, and wonder about the experience of others. Is anybody running two Mates with LiveTV off the same Moxi 3-tuner DVR?
With that basic theme, here are some comments and some bugs I have found. Moxi support has been very responsive, although they have not fixed my problem and I think they are wrong to blame my network configuration. I went so far as to disconnect my entire network and rewire as a test with simple w Mates and one DVR connected to a router connected to DSL and I had the same issues on the Mates with Live TV.
Issue #1: Moxi Mate responsiveness. Even when I am not pairing both Mates on the same DVR, when each Mate is paired to a different DVR, changing channels is at best a sluggish process. The guide and channel banners come up instantaneously, but I get a 3-10 second message "Please Wait" before the tuned channel appears. While I can live with this, my wife screams. It is particularly irritating when trying to switch back and forth between two channels. And this is not the worst of it, sometimes the channel guide itself goes away and I just get a "Change Time Slot" message instead of a channel list.
Moxi support has led me to look at the bandwidth the Mate is receiving by going to the Media Link screen, choosing get info, and then choosing check connectivity. I have found that with one Mate tuned to a DVR connectivity is generally between 80-95 and when two Mates are tuned to the same DVR, connectivity drops to 60-75. Poor performance on the Mates seems to correspond to connectivity below 85 (although the delay for programming on LiveTV I cited above happens even with 95 values for bandwidth).
My units are all connected with ethernet Cat5e wiring. My home network seems to run at gigabit speeds (at least the 1000 baseT display lights come on with my Dlink switches). The network is large and it is an extended star, with a DSL modem, a router and a switch in the center, and another dlink switch at each branch (connecting, generally, the Moxi unit, a Macintosh, an Apple TV, and maybe a wireless access point, one per floor of my townhouse). I did a network survey and their are 24 IP addresses on my network assigned by the DHCP of the router, but this should be a workable number. I am speculating that the Moxi Mates themselves are the limiting feature (100 base T limit) and that running multiple streams from one DVR to two mates causes bottlenecks. Not sure what else could be going on.
Bottom line here is that I would like to see the bandwidth and channel changing speed on the Mates improved. The DVRs themselves are very responsive.
Issue #2: Tuner usage. When the DVR is recording, one tuner is used for the program being recorded. A second tuner is used for whatever the last channel that unit was set to, even if the TV is off and no one is watching it. Unlike the Mates, the DVR does not release its tuner when not in use. This is problematic if someone tried to use a tuner from a Mate. The Mate comes up with a message that one tuner is being used for a recording and one tuner is in use. The Mate, in theory, allows you to drop eitherr the recording or the other show. In practice, dropping the recording works fine, but dropping the channel that is live on the DVR (though the TV is off and no one is watching) fails. This is a bug. Moxi shoudl hopefully address it.
Issue #3: Random power offs. Like some of the other users here, I have had a few random shutoffs, where my DVR seems to reboot for no reason. Only happened twice, but completely unexplained. The log was sent to moxi and they have a ticket open on this issue.
Issue #4: Pairing Mate and DVR. This process does not work as well as it should. I doubt there are many users yet who have multiple DVRs and multiple Mates, but there likely will be with time. Right now, it is difficult to determine which DVR a Mate is paired with and very cumbersome to change once paired. The only way to change a pairing, I believe, is to unplug the Mate, unplug the DVR you want to pair with, boot up the DVR, and then boot the Mate. The Mate pairs with the last DVR to reboot. My suggestion is that (1) Moxi establish a better pairing process and (2) Moxi put in a banner to identify the DVR a MAte is paired with.
Having said all of this (and it is a long entry I realize), I actually like the Moxi. The picture is probably sharper than the one TWC delivered through the SA8300HDC boxes and better than the one on my Samsung HD box (I think 3090). Also, and most significantly, having the ability to watch recorded shows in any room is key. This is why i bought the Moxi and this is unmatched by TWC or by Tivo.
post #1503 of 5911
To the MoxiGuys - questions.
For engineering/marketing:
1. Can a few minutes be added/subtracted from the start/end times of a scheduled recording. Does the current network trend of ending a program at, for example, 10:01pm eat up a full 10pm-11pm block? I am routinely trimming these to end at 10:00pm to allow another program in the 10pm-11pm block.
2. Still no way to manually record? In the "unlikely" scenario that Moxi/Arris stops providing an IPG, will the Moxi DVR be worthless? Having the ability to schedule a recording manually eases this worry.
For sales/marketing:
1. When will the 3-tuner model be available without having to get a Moxi Mate? I need 3-tuners in a time-slot often, but currently have no need for a Moxi Mate. The absense of an ala carte 3-tuner model makes me want to hang on and see what the Cox/NDS 16:9 HD IPG is all about. An unbundled 3-tuner Moxi just might make me less curious.
post #1504 of 5911
Originally Posted by pgershon View Post
....Is anybody running two Mates with LiveTV off the same Moxi 3-tuner DVR?
Issue #1: Moxi Mate responsiveness. ... The guide and channel banners come up instantaneously, but I get a 3-10 second message "Please Wait" before the tuned channel appears.
I think quite a few of us are running 2 Moxi Mates on one 3 tuner Main Moxi. If both Moxi Mates are using Live TV (assuming you are on a different channels), then you have one tuner available on the Main Moxi. Your main moxi can either watch TV or record 1 channel while watching a recorded show.
However, you can watch Live TV on the same channel on all devices (Main Moxi and Moxi Mate), then you have two tuners available to records shows.
In order words, each tuner is tied to a channel.
I have the main moxi and one moxi mate connect via a network cable and one connect via MOCA. It works just fine. We had another user who accidentally used a separate email account for the Moxi Mate.. Make sure all units are activated under the same account.
Issue #1
I think everyone gets that Please wait for 3 to 10 seconds when watching Live TV from the Moxi Mates. I do not think it has to do with network issues but rather.. just how it works. The Moxi Mates and the Main Moxi are negotiationg a connection to transmit the channel live. Right.. you can't channel surf per say... but you can browse the guide and then select to a show you need. I think wait 3 to 10 seconds is okay to stream a HD live show....
I done this numerous times, you should be able to force the main unit to give up a tuner for the Moxi Mate if two shows are being recorded on the main moxi
post #1505 of 5911
In order words, [i]each tuner is tied to a channel.
I understand this. My problem is that when I have 2 Mates tied to the same DVR, neither Mate will keep the channel list for LiveTV. The bandwidth the Mates receive drops to the 60-75 range and the units fade in and out in terms of responsiveness. I go 60 secs or more unable to tune any channel on the Mate. Finally I am forced to pair one Mate per DVR and the Mates function properly again.
Is there any reason to believe these units will work better with MOCA than with standard ethernet cabling?
Issue #1
This is more of a problem than you giver credit for. I frequently tune back and forth between two shows - sporting events come to mind. The "please wait" delay is a real problem for this. We have a previous channel button (jump) but it works poorly on the Mates because of the delay.
Not sure what to say here. I get the choice to force the unit to give up the tuner, but it refuses. It will kill a recording and giive me the tuner on the Mate, but it will not give up the tuner that the DVR is set to but not recording. Again, the option to forcefully take the tuner is there, but it fails to work.
post #1506 of 5911
The drive can be cloned. I sucessfully cloned it to a 2 TB drive, and the unit boots and runs fine. Bad news, it is an unknown filesystem and I couldn't see or expand the partition. Used g4l in raw clone mode. Freeware
post #1507 of 5911
That is still great news. That means we can make a backup of the drive to cover drive failure.
What type of drive is the original 500GB?
post #1508 of 5911
seagate st3500321cs
post #1509 of 5911
One other thing - I cannot get my slingbox remote to control the Moxi. Not sure why
post #1510 of 5911
Maybe you should connect the main Moxi to the TV you watch sports on then. Or switch to your cable to watch live TV.
Of course you could just buy another Moxi.
Dave
post #1511 of 5911
All,
There is a newly released update.
I believe this update addresses an issue some of us had with external drives having random 10 second freezes on shows on the record drive. Not sure if it does anything else.
To force this update, go to Options, the Diagnostics, then Service Status.... select Update Moxi.
It should say New software is available..
Select Update Software..
This will require a reboot.
I don't see any update? Since 6.1.0.25R4BR-P.30145O
post #1512 of 5911
Dave
While I think you meant well, the first option doesn't work well if I watch sports on multiple TVs.
Switching to cable not an option as most channels not clear QAM so I would need a cable company STB ($7.50/month).
Buying another Moxi DVR not a great option now that I own the Mates. Also not free.
Besides, the delay is likely something the Moxi people can fix. Recorded TV plays without the delay. My guess is that the delay relates to the Moxis navigating for an unused tuner. The delay is even longer when the Mate comes back with a tuner not available message.
As I said the Moxi is a very nice product - I am just not sure it is 100% ready for primetime.
post #1513 of 5911
Issue #1
It appears this would be another reason to consider buying two 2-tuner Moxis over a 3-tuner Moxi and mate.
I listed some other reasons in the post below.
http://www.avsforum.com/avs-vb/showt...2#post18138962
post #1514 of 5911
What I meant is that in my opinion, it's not realistic to expect a Mate to perform the same as another dvr would.
Dave
post #1515 of 5911
I think the above text needed to be highlighted with a different size font. So creating a backup drive is no longer an issue.
bellaireroad,
Do you have detail steps? How long did it take?
post #1516 of 5911
After reading some of these posts, I would tend to agree. I think I'd rather have two fully functional and quick DVRs for the same price as the 3 unit package. It seems that it's worth sacrificing one Mate for this added functionality.
post #1517 of 5911
I find it interesting how many don't like the Mate sluggishness, when I would switch my main DVR and mate location if the Mate only had the grid guide and programming ability.
For me, the main DVR is very slow to respond to all inputs, frequently taking multiple attempts (and I've eliminated the possibility of this being attributable to IR send/receive issues) to execute the commands. Moving around the grid guide is an almost painfully slow and frustrating experience, and the normal guide is not much better.
In contrast to this, my mates respond almost instantly, with multiple-succession quick button inputs yielding exactly the response they should, and overall snappiness in the interface. I'll admit there is a delay when changing live tv channels, but that doesn't bother me since I generally never channel surf.
If (when?) Moxi adds the grid guide and programming functionality to the mates, it's a no brainer for me - my main DVR is going in my infrequently used office and the mate is going in the family room.
post #1518 of 5911
Sorry you are having such problems. I have a 3 tuner Moxi with 2 mates and now a second Moxi with 2 mates on my network. I have had no difficulty running 2 mates with the 3 tuner moxi. I don't get a 3-10 second "please wait" for the channel line up. The mates are not a limiting issue on my cat5e network so I suspect something is amiss in your complicated network. Perhaps some formal transit times across routes inyou network will reveal a problem. I sometimes get the change time slot menu which is always a choice in the menu and I simply back out of it .
So far I have not had unexpected power-offs.
The pairing is an issue I have not explored yet. I would hope the mates could be easily re-assigned or automatically access an open tuner on any Moxi; but, I guess that isn't the case. I'll have to explore further.
post #1519 of 5911
It should be at 6.1.0.26R....
AFAIK, this update was to address an issue with some of us who have external drives that had issues with the stuttering of playback. If you never experience this, there is really no difference between 6.1.0.25 or 6.1.0.26.
post #1520 of 5911
Here are some instructions for using G4l (Ghost 4 Linux)
http://www.oakdome.com/lab/?page_id=8
Here is the link for the ISO
http://sourceforge.net/projects/g4l/
post #1521 of 5911
Originally Posted by flyer57 View Post
Anyone have recommendations on using the Harmony 1100 with the Moxi? as setup with the wizard it doesn't really function. I have ended up using the Moxi remote. Any help would be appreciated
I ended up manually adding most of the controls. There is a Moxi MIR1500-T3 device in the Harmony list that is pretty close. I believe I only needed to add IR for a 2 or 3 buttons. There were many "buy" related buttons that needed to come out however.
post #1522 of 5911
Actually, the "please wait" comes on after I have seen the channel line up and tried to change a channel. The wait time is when the new channels is being selected for the screen. There is an episode of Star Trek TNG called "Future Imperfect" where the computer seemingly becomes slow to answer and flashes 'please wait" type messages when asked for historical data. This banner seems eerily similar.
The change time menu comes up for me, at times, in place of the channel lineup. It is not something I can back out of. If I go to another menu and go back, generally the change time is still there and the channels are not. Eventually this fixes itself, but it should not happen.
post #1523 of 5911
pgershon,
Please call Moxi and log a ticket for each bug you have.
The live streaming was released a couple weeks back. Give Moxi some time, I am sure they can minimize the please wait screen.
post #1524 of 5911
bellaireroad,
the instructions you posted sum it up. It took 2 hours and 10 minutes.
post #1525 of 5911
I am considering a 3 Tuner Moxi and Mate, but wondering if now is the time. I live in PHX, AZ, a Cox SA/Cisco market. Cox confirmed their SDV tuning adapter supports only two tuners. I assume at some point that could change. Having an OTA connection could help with this issue.
My questions.
1) Moxi documentation makes no mention of support for AVI files, Yet I found three reports on this forum that says AVI files do play. Most my library is AVI. Is AVI supported?
2) Is there support for RealPlayer or ITunes?
3) Why isn't there a clock on the face of the Moxi, petty I know, but I'm pretty used to seeing the clock and channel on the STB.
4) Will Moxi support cable's VOD service in the future, and will that require a software or hardware update. I use VOD frequently and am not keen on paying extra for a subscription to a VOD service.
5) Moxi documentation sugests the ethernet connection should be greater than 100Mbps, Yet the technical specs state the ethernet port is 10/100 Mbps Cat 5 Ethernet.
6) How does the Moxi manage recordings with an external HDD? (ex. SA8300 records the show to the drive with the most availible space)
Is there a tech spec sheet for the Moxis, I can't seem to find one. Also a list of software/firmware updated and their descr.
Thanks in Advance.
post #1526 of 5911
Would love to know how others have filled in for the clock. Not a real issue for me, but my wife and 11 yr old son keep complaining about the lack of clock. One thing that was nice about the STB clock is that each unit said the same time. I can install digital alarm clocks over the Moxi boxes, but the time will no longer be synchronized with recordings nor with each clock in the house.
post #1527 of 5911
I also missed having a front panel clock, but have since added a Sony HD Radio tuner to my entertainment cabinet which has a nice big clock display. It has similar blue LED backlighting like the Moxi and the brightness can be adjusted. I just syncronize it with www.time.gov which seems to be right on with the Moxi internal clock.
http://www.sonystyle.com/webapp/wcs/...52921665401984
post #1528 of 5911
Moxi is DLNA certified. On their website it states WMV video. However, you can play additional formats such as AVI using Playon or Twonty Media software.
No, RealPlayer and Itunes are not DLNA certified so they are not supported on Moxi. However, you can probably play the files using the above mentioned software
Sometimes I wish Moxi can cook dinner for me...
A quick push on the menu should bring up a screen with the clock on the TV
This probably will not happen any time soon. This not not available with Moxi or Tivo. However,keep your eyes on Tivo March 2 event..
10MBps is not enough. 100Mbps should be fine.
Fairly seamlessly. If you plug in a eSATA only connector external drive, it will show you the available space between the internal harddrive and external harddrive. In other works, 25% used is 25% of both the internal and external drives combined. Recordings are integrated in a seamless list.
I have not seen one.
post #1529 of 5911
Originally Posted by Evangelo2 View Post
I have the same issue. I tried many different encoding tests as well with no success...
mp4 with AC3 (DD) passthrough - FAIL
mp4 with 5.1 AAC Audio - FAIL
My receiver NEVER gets the audio via ToSLink...
A slightly different question here...
Will the Moxi put the AC3 bitstream onto the HDMI output so an audio receiver can decode it? I know that HDMI can pass 6 (even 8) channels of PCM, but I only want the native AC3. There are lot of audio decoding settings on my AV receiver, and I don't see a whole lot of choices for AC3 decoding in the Moxi itself.
I hope it's not some automatic HDMI configuration thing, because I'd really like to have the two channels of HDMI audio be AC3 and not downmixed stereo PCM.
Any ideas?
post #1530 of 5911
So I'm thinking of getting a two or three room Moxi bundle to use with my Comcast cable. I've been reading about the lag when channel surfing on the Moxi Mates and that concerns me a bit. I will be connecting the boxes to a wireless-n network using a wireless ethernet bridge (TRENDnet Wireless N Gaming Adapter TEW-647GA). Do you think that the mates would lag? I'd expect the mates to work just like a cable box with the ability to view recorded programs from the dvr. I pay around 35 bucks a month for Comcast's dvr and hd boxes so the Moxi system will soon pay for itself. Any advice I'd appreciate.
  Back to Forum: HDTV Recorders
