Comcast Tech Support:
If you are using one-way CableCARD equipment (other than a TiVo Series 3, TiVo HD, or TiVo HD XL DVR)* and would like to continue receiving channels delivered by SDV, we can:
Option 1 - Replace your CableCARD device with a standard set-top box at no additional charge.
Option 2 - Replace your CableCARD with a high-definition (HD) set-top box at no additional charge for 12 months.
Option 3 - Replace your CableCARD with an HD-DVR set-top box for $9.95 per month for 12 months.
You may choose not to use a set-top box; however, will not have access to the channels that utilize the new SDV technology.
You will continue to receive the other services and channels without interruption.
Me:
So they work fine with Tivo? How many channels use SDV?
ComCast Tech Support:
Yes they do.
I just ordered 2-Moxi 3 tuner DVRs and setup an appointment for installation of 2-Mutli Stream CableCards. My question is Moxi does not show the SDV channels but Tivo's do? Why is that? Is the Tech Support wrong somewhere and why when I ordered the CableCards would they not tell me some of the channels would not work? I got the channel list and its pretty much all channels I don't get anyways (but like two) so I am not that upset, but I don't want to receive my Moxi's and not receive channels. Am I missing something?
Thanks for all your help! And Long Live the Moxi!!!
Me:
Yes they do.
TWNEO is supposed to have everything running correct at the end of the month but that is dangerously close to my 30 day return for the moxi...
