I have been chatting with a pal who is not an AVSer, but a serious geek/engineer/programmer (he was one of my "outside" contacts/advisors back when I was managing smallish software development projects in publishing). For sure one source of a lot of what I know. We talk about DVRs, the software that runs them and the possibilities for third party sources (which we both SERIOUSLY believe in). He had been a TiVO guy, and if the information didn't already exist, he'd have been tinkering trying to figure out how to increase his internal disk size. I had alerted him when I first read about the big Moxi price drop (and lack on monthly charges), heralding a serious run at the business from the new owner of the Moxi tech and he HAD to get one.
I had mentioned to him the discussion around the possibility of upgrading the internal drive, and wouldn't you know, he just HAD to figure it out. Naturally, he DID figure it out!
Now before I go any further, some serious caveats are in order. I HAVE been clear about what I consider our responsibilities as end users, about how I operate on a sense of fairness both to the company and to us as customers. I am further informed that in very recent memory, end users figured out how one COULD upgrade an internal drive in a cable supplied DVR (the Samsung 3090), but only in one very specific fashion (it seems only one specific drive can be used, a 320G Seagate model). In reality this information, publicly available on AVS, did NOT hurt either Samsung or the cable co. in any way, but DID help out a lot of customers when the cable outfit didn't' see any need. The irony was that the NOW, cable outfit is also dribbling out units already equipped with the same 320G drive... BUT customers who already HAD made the upgrade did NOT have to go back and swap their equipment, thus there was actually LESS burden on the cable outfit that owned the boxes. CLEAR win-win.
First, doing this can be thought of as violating the warranty (also there is the end-user agreement mentioned above). If you are at times kinda ham fisted, or are nervous in any way, don't bother. There is every possibility that at some point, Moxi WILL have a 1T model alongside it's 500G, just like TiVO now does. Not to mention Moxi actually KNOWS how to support external storage properly, so one CAN add 2-4-6T of additional external storage. That being said, if you are very careful, you CAN swap back the OEM drive and leave little evidence you DID mess with the unit.
The only thing that made me pause was us having "Moxi-Guy" around... would this information scare/p*ss him off? It's judgement call and I think not, given what he has already said and posted here... I think he completely understands this CAN come out and JUST like TiVO, was inevitable. And like I've already said, this information being out sure makes a BIG plus to those on the fences about going Moxi.
Lastly, there is NO guarantee whatsoever that this will work for everyone, or even anyone else. Don't cry to me if it doesn't... there is some level of risk associated with doing it (as there is for the Samsung thing I mentioned, or any TiVO user upgrading their internal drive [interesting to note there seems to be actual businesses who do that upgrade FOR a price]). It COULD be you try it, it doesn't work, you replace the OEM drive and it still doesn't work (i.e. not for the faint of heart).
Enough caveats for y'all? AT YOUR RISK, but you CAN upgrade the internal drive... someone has using these steps"
1. Shutdown Moxi by unplugging the power
2. Open case, remove original HD, install empty 1T/1.5T SATA drive being VERY careful touching anything else in there
3. Boot up the Moxi and hold the up, down, left, right buttons on front of the Moxi (4 button press)
4. You will be presented with the screen posted earlier in this thread <<a href="http://www.avsforum.com/avs-vb/showthread.php?p=18461470#post18461470" target="_blank">http://www.avsforum.com/avs-vb/showt...0#post18461470 > with the "re-install" message
5. Make sure you are sure you want to delete everything (i.e. first watch all the recorded stuff, write down series recordings etc.).. then click OK.
6. This part took 30-40 minutes (rough guess, it was not timed) and does not give you a status screen
7. Run through system setup
8. You are done!
He said there was no indication in the UI that you had more space... you only REALLY know that once you start adding recordings.
It worked for my geek pal, I've know him long enough to 100% trust it DID work, but once again, YMMV! Personally, I am extremely tight with money, so I look at a lot more angles before any $$ goes out, but the fact this info now exists sure as hell moves a Moxi up the list (AND a clearly written policy what happens AFTER the 90 days/1 year warranty period I also need).
8. You are done!
