Originally Posted by sslund
Now I'm in a total panic . . . apparently, there is no way to use static IP addressing with Moxis. I am annoyed beyond belief because I specifically called to make sure this wouldn't be a problem before we ordered, and now it is.
From the couple of responses I've received here so far, it sounds like there might be some way to work around our need for static IP addressing for some of our equipment with DHCP enabled, but I'm not understanding the whole range thing. Can someone explain it in really simple language? I don't even understand the range part in phousley's explanation.
I did find this in my router instruction manual:
"Static IP
The administrator can assign the Static IP for the specific client based on this user's MAC address. Enter the Static IP Address, MAC Address and Name, and you can check the box to enable this rule or not. The administrator can configure the Static IP Address as 0.0.0.0 with the specific MAC, so the computer with this MAC can get IP address from RV082 DHCP server but without Static IP limitation. Checking "Block MAC address not on the list" box can enable MAC Filter function, so only the MAC address on the list are allowed, and the others will be blocked. Once complete the rule setup, click the Add to list button. You can set up to 253 MAC Addresses."
Could I enable DHCP on the router and use a range of something like 192.168.1.100 - 192.168.1.105 for the two Moxis and two Mates, and then use, say, 192.168.1.110 and up for everything else that's already configured for static IP addresses?
Since I'm in a serious time crunch with the cable dude coming in just over an hour, is there a range I can use when enabling DHCP that will prevent me from having to reconfigure everything on the network? The IP addys I've been assigning throughout the years start at 192.168.1.20 and go up through 192.168.1.99 In the instruction manual, there's a screen shot that makes it look like I can enable DHCP and still use static IP + MAC by entering them in a table, but I'm just really confused . . .
"Static IP
It's all in the router... I doubt the Moxi cares, I think it just requests an IP and gets one from ther DHCP server that is running IN the router. Sounds like your router is capable of doing what I said above, essentially pre-assign specific IPs to each specific device (.i.e. each Moxi pieces MAC address).
However, I do not THINK it HAS to be done this way. I THINK you can not enable any MAC filtering or IP assignments in the router and it will do it's thing.
I've been trying for months to show him the difference by having him compare the HD picture through the cable box as opposed to the non-HD picture through the non-HD RTVs, but he kept saying that he didn't see any difference. His comments today vindicate me
