Thanks Ken. Really looking forward to your and Daves reviews.
The software/guide I had with my previous Moxies was so much better than what we have now. I really dislike the ads all through the listings. And there are many other things, like no way to accurately jump past commercials, and the fact that the search function finds a show on an SD channell and then you have to physically scan the listings to find if and when it's broadcast in HD. This is a major PITA often you end up with a series recording set to the SD version with no way to change it, you have to delete it and find the listing manually to reset. If the show airs several days hence, it takes forever to scroll through all the listings.
Dave
Dave
