Originally Posted by
DoubleDAZ
But are you also saying I can't use them with my Linksys router? I though all I needed to do was place an adapter between the wall and my modem and then the wall and the Mate to get everything to access the network. No?
You can certainly use your Linksys router. But an Actiontec MoCA router can take the place of a MoCA adapter, and they cost closer to $20-$30 than $70-$80.
I have a Westell 9100EM MoCA router connected directly to my D-Link router -- I got it for $20 on ebay. I have a Motorola NIM-100
or Actiontec MoCA adapter in each room with a PC, server, or CE device. You can connect a network switch to the ethernet port on a MoCA adapter to give you more ports.
DoubleDAZ
I have a feeling I'd only get Netflix on the TV the LG 370 is connected to.
That's correct. The LG does not provide your Moxi access to Netflix. You need the PlayOn software for that.
DoubleDAZ
Better suggestion? I have no attachment to LG, so I'm open to anything. Samsung 3600? Something else.
The Blu-ray players with the best DVD playback don't seem to support Netflix, unfortunately.
If I were buying a new Blu-ray player today for my Kuro (which supports 24p), and I wanted Netflix support, I would get the LG 370 or LG 390.
qz3fwd
I am considering either a Moxi or another S3-both look very good asthetically.
I wouldn't buy a S3 at this point. I would either get Moxi or wait until January to see what TiVo offers with their DVR refresh for Best Buy.
qz3fwd
Q2. Can you extract content (w/appropriate CCI flags) like firewire method or tivo desktop method.
No. The Moxi does not have Firewire, and they do not provide any form of transfer/offload functionality.
qz3fwd
Q3. Can you stream HD m2ts/ts/mkv from network storage? (Mpeg2/VC1/AVC)
The Moxi can decode MPEG-2 and MPEG-4, but I'm not sure how the PlayOn software handles the streaming of the M2TS/TS/MKV formats. Perhaps VisionOn or another member can test that.
If you're looking for dedicated media player to play all videos natively, without software transcoding, then Moxi may not be what you want. AFAIK, Broadcom's current DVR CPUs can't handle the high bitrates used on BD disks and full-size BD rips, nor can they handle DTS or Dolby Digital @ > 448Kbps.
