So here is my theater. My father in law has his own company and they actually do the screen, drapes, and decor of actual theaters so naturally I had help from him.
I started out with just a typical 2 car garage. Onced finished the room is about 14 feet in front to back depth and about 11.5ft in width. The framing was done with 2 x 4's and then dressed with sheet rock.
Next is were it gets really cool, we framed out the inside the theater with one inch by one inch mdf along all the corners and edges so we could cover the walls with acoustic installation fiberglass then cover the wall with a grey tension mount. We then covered the edges with black base board and black trim.
The biggest task was to be able to open the garage door but not have it in the theater so we did a tension mount across the ceiling in the front of the theater just to were the garage door will open to and then the garage ceiling is used and was painted black. Thge result is a garage door that opens but you would not be able to visually tell while in the theater.
Sorry but the pics are from my phone but you get the idea.
